For the life of me I cant make this work. Netgear WNR2000 wireless N router. I want to plug it into an existing network, but use it only as an access point. yes, I know I should have just g...
Have a WM 6.1 smartphone with WiFi, corporate network (Cisco Aironet 1200) configured and functioning using WPA2/AES/PEAP. When attempting to connect to this SSID and entering domain username...
Can anyone show me how to configure a Cisco Aironet 1250 to use WPA without and authentication server. According to the specs on the 1250 it says you can do it, but I cannot find any wr...
Hi, I would like to change BSSID on Guest SSID to 0011:2233:4455 MAC on 1242 AP!
I have a Cisco 2100 Wireless LAN Controller with three Cisco 1130 Lightweight Wireless Access Points. I have two WLAN's configured on this wireless system, with one being on the same VLAN/Subn...
Trying to get a notebook to connect to a Wireless network it says it cannot find, but verification says it is there as well as another computer being connected via CAT5, D-link DIR-615 indicat...
I recently configured our Company wireless for PEAP authentication with Microsoft IAS.
So far everything looks good, the only problem im having is that user complained about disconnect...
Hi All
After doing some more work my previous question asked titled "IBM Lenovo Wireless Adapters take longer than normal to activate" I have found the problem.
The common denominator I ha...
7700 dlink ap The device is mounted 50 feet in the air. I can access the device through my web interface. It prompts for a user name and password. I don't know the username and password. P...
I'm currently running Windows Vista on my Macbook using Bootcamp and I'm having some difficulties with the wireless internet connection. The internet would work perfectly when i'm about 5 feet...
Hello Experts,
My environment consists of about 2000 users who need access to internet. The network topology is Wireles LAN.
The requirements are:
-Users must not do any configuratio...
Ok folks, I have read all of the docs and still cannot find a straight forward way to setup guest access on a Cisco WLC 4400 series. Please point me in direction that is clear enough for someo...
Hi, I have a laptop set up and have an Internet connection available with a Local Area Connection or a connection using a Wireless Router. What I am hoping to do is have all network recourses...
I have found this same issue on a couple of IBM/ Lenovo laptops with inbuilt wireless adapters in them. It could be a coincidence though. I find that after the laptop boots to the desktop, ...
I'm trying to decide what encryption cipher to use. Currently we're using TKIP but I'd like to upgrade us to WPA2. One of my coworkers said that AES CCMP + TKIP is the strongest, but I feel li...
We just got a wx1200 wireless controller and 5 3850 access points. We had a company come in and configure everything. Problem is, nothing seems to work. We have a 3COM 5500G-EI-48PT SWCH. The ...
I use my laptop to work with all of my clients. I require connect back to the office to lookup some information. I have considered buying a 3g card and plan, but they are expensive and ...
Experts,
I am trying to setup wireless connection from a PC to security DVR system each locates in separated buildings. Because two building has a little distance, I am going to use Linksys W...
We are running a cisco WLC 4402 in a environment mixed with windows xp and windows vista.
Lately we have had loads of reports from users with windows vista not being able not log on to our wi...
Hi there. I wanted to see of any one has any options better and much lower in cost to Cisco's NAC appliaces(> $60K). I would be interested in even a chilispot setup with step by step instruc...
I know this is not a correct scenario for DHCP but the IT staff at my company (who shall remain nameless) has multiple subnets and there is a DHCP server on each subnet. So far so good but sys...
Guys,
We had a Wireless LAN controller set up, and it was working great. I was on the http interface and wanted to set it up so it authenticated to a TACACS server, but i must have had made...
I work for school and they have 10 access points. Each access point has the same SSID & network key. but whenever we search for the wireless access points it shows 10 SSIDs instead of one and ...
Hello everyone,
I have been given the job of a business school, to make or find a system that allow teachers to disconnect the wireless network for a specific group of students, so they ca...
Wireless connection issue
I have 2 laptops that I am trying to connect to the wireless network.
we have an AP, and usually when there is a guest to the company we just plug their laptop, a...
