Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested WLAN Solutions: 1 - 25 of 269
I recently purchased a HP Compaq Presario B1900 (B1959TU) which came with Vista Business. Not being a mad keen Vista fan, I installed XP Pro instead but now I can't get much of the hardwar...
I just reinstalled Win XP on a Toshiba Satellite A45-S151 laptop.  I went to Toshiba and downloaded the driver for it at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp.  I install...
What I need: A way to export the wireless networks from a user's XP SP2 machine and import them on a new XP SP2 machine. Why: We have many users that use wireless networks at home but are...
I can't see the WPA2 option in the menu.(See picture) I think I have the driver correctly installed, I can connect to an unprotected wireless zone. My device is the Atheros AR5001X Mini PCI Wi...
Hi, My workstation has wireless connection, VPN connection built on top of it. Both wireless and VPN use dynamic IP. I want to use VPN connection as default gateway so all communication is se...
I mistakenly bought a Cisco Aironet 1131AG that comes with the lightweight version of the software (designed to use with a controller, part# AIR-LAP1131AG-A-K9), while what I really needed was...
I'm working on an IBM ThinkPad G41.  The machine could not connect to a wep wireless network originally, I have another G41 with ThinkVantage Access Connections installed that has no problem c...
I have a Dell XPS running Vista Home Premium, and I can not get it to connect to a wireless network. When Vista first boots I get this message at startup. Your W-Fi Catcher band configurat...
The wireless network is in range but it keeps saying it cannot connect because it might be out of range. It is a Dell Vostro 100. I have tried the microsoft fix and uninstalled and reinstalled...
Hello, I have a Belkin F5d-7230-4 UK7001 version wireless router which I use in conjuction with a Belkin Wireless Range Extender (or WURE).  I have a problem where my laptop (dell Inspiron ...
A wireless network currenty uses WEP.I would like to increase its security, migrating some clients each time to WPA2. All access points are cisco 1200 series To do that i have to enable "mi...
I'd like to extend the range of my no-brand access point (without laying other cables). There seem to be 2 possibilities for this: either using another AP configured in WDS/repeater mode or us...
I have a Dlink DIR-625 router.  It has the latest firmware.  It will drop the wireless connection with both of my wireless network cards periodically.  No real helpful messages in the system l...
Hi all I have around 10 wireless network connection configured on my laptop and I would want them to manually copy my entire Wireless network setting for the backup purpose Is their any ...
I have a both a Linksys and a Belkin wireless network running. The belkin wireless router is also an ADSL router and is connected to the internet, on the LAN port it is connected to NIC 1 on a...
I have recently got a new company laptop, a Lenovo ThinkPad T61. It has a built in wireless adapter - Intel Wireless WiFi Link 4965AG The laptop is fine at work, it connects to the wireles...
We have been having some trouble recently with clients roaming between access points.  When they roam off of one AP onto another, their application sessions (medical records software) disconne...
Presently installed and working Speestream 6520 Router with wireless enabled. Static IP's setup. Want to install another PC in another room using the D-LinkWBR2310 as an ACCESS Point. Cannot g...
I need help getting my wireless network card to work. Someone has inadvertantly made it malfuction but we are not sure what they did. When i try to connect it says no wireless networks foun...
I want to set up a radius server to authenticate wireless users on our network. I'm using the MS IAS server, and Cisco Aironet 1200 AP's. We have 700+ users, many of whom have very little k...
Sony Vaio VGN-C1S running XP Pro used to use a Vodafone 3G dongle which gave lousy connectivity. I have uninstalled the Vodafone software to try reverting to the internal wireless but when see...
I am a Cisco wireless engineer and deal with enterprise roll outs of Cisco wireless networks.  Lately, I have been working with schools that allow students to login to a laptop (not their own,...
On computer restart %SystemRoot%\system32\services.msc /s must be opened in order to open Window's Zero Configuuration and manually start WZCSVC. Despite being Startup type being set to automa...
We have a total of 4 Aironet Access points (1100 Series) around our building. Is there a specific way there should be set in order to not drop packets as we walk from one end of the bldg to th...
Hi, I have just had new wifi installed on my network. It is WPA/PSK authentication and TKIP encrypted. The network is broadcasting. My laptop with XP SP3 connected fine and work with the co...
