I have a Cisco wireless LAN controller that I use to control three access points within a two story building. At this point in time I'm the only user but will be adding many more soon. Each ...
I need help getting my wireless network card to work. Someone has inadvertantly made it malfuction but we are not sure what they did.
When i try to connect it says no wireless networks foun...
I have updated all drivers for Wireless Adapter. Also updated software. Software says to turn wireless on. Hardware says it is functioning but will not connect. I have used lenovo's rescue...
I have a Fedore Core 6 and need to create my own LAN.
Currently my computer is connected to a wired LAN (eth0:128.32.186.22) and to a wireless network (eth1:169.229.253.102).
I need to s...
I have an Acer Aspire 5520 Laptop Computer running Windows Vista Home Premium equipped with an Atheros AR5007EG Wireless Network Adapter, a 650MHz desktop computer running Windows XP SP2 or 3 ...
A Windows XP Pro computer cannot connect to any wireless network, using any wireless adaptor, despite three other computers / printers being able to successfully connect. The security is basic...
I have 30 Dell Latitude D620 s who's purpose is to be used as a mobile laptop lab in the the school I work for, the laptops have a issue when connected through the wireless network. The laptop...
Problem Description:
1. Click on the wireless connection icon in the system tray to open "Wireless Network Connection Status".
2. Click on "View Wireless Networks" to open the "Wireless N...
Hello experts
This one is a puzzler. On a client's laptop I can connect to the wireless network, but only if I make it unsecured. The machine can see the network but when i tell it ti con...
On computer restart %SystemRoot%\system32\services.msc /s must be opened in order to open Window's Zero Configuuration and manually start WZCSVC. Despite being Startup type being set to automa...
I have a new Vaio laptop VGN-NR21E laptop with which I am unable to wirelessly connect to my D-Link DI (or DL)-542UP router. My work laptop, My girlfriends' laptop and even my Palm T...
I've asked this in a different form elsewhere with no answer yet, but I'm going slowly nuts trying to figure this problem out: My ultimate aim is simply to get my dual core, XP PC to send musi...
I have a wireless router running DD-WRT. I want to put this router on my existing network to allow my guests access to the internet, but not to my existing LAN. Does anyone know how I can do t...
I was wondering if anyone knew what ports or protocols were used by the YouTube application on the iPhone. I have one that is getting blocked one one wireless network that has an Endian firew...
I have a Dell latitude D830 with windows XP pro and an internal Intel 4965AGN wireless adapter. I am trying to get it to connect to a D-Link DSL2740B Wireless ADSL router at 108Mbps, but it wi...
I am trying to setup WDS (wireless domain services) on a set of cisco 1131AG access points. Why do you need a radius server? What does it actually authenticate? The clients? APs? I need an eas...
I have a desktop computer running XP home SP2 directly linked to a wireless router. I also have two other notebooks on same OS linked on wireless network to the desktop. Internet access works ...
I have a Cisco AP 1100 with Windows 2003 domain - Standard edition is my servers. I don't have any enterprise 2003 servers.
I am trying to setup WPA based on this Microsoft Document:
Step...
I have a DHCP (single subnet) set up on 2003 SBS. The server is wired to a Linksys WRVs440N router with DHCP Relay enabled. Wired clients recieve IP addresses correctly but wireless clients ...
Is there an easy (rather than trying to capture the changes with regmon) way to centrally change the wireless network priorities in XP? I know in Vista it can be done with netsh set profileord...
I would like to have the wireless adapter switched on when the laptop boots up instead of having to hit the FN+F2 key before I can connect to the internet.
The basic scenario is this. We wish to constrain a wireless client to only connect to a single SSID. So far, we know how to use group policy to prevent the client from automatically connecti...
What would be the simplest way to setup a secure wireless internet service as a 'public' hotspot utilising the current Lan's internet connection, without the 'public' gaining access to other L...
Red X in WLANTRAY (Wlan Tray) denoting no wireless network connection for 60 seconds - Dell XPS 1530 with Vista and latest drivers (just received June 10, 2008)
Upon boot, I get a red X in...
I am trying to get an Apple iBook running OSX Panther to share the Epson R1800 printer attached to my PC running Vista Ultimate (2.66Ghz Quad Core 4Gb RAM). I have set everything up on the PC...
