I got Verizon FIOS (15/2 mbps package) installed last January 2007. I've been searching the forums to see if other users have experienced slow wireless speeds.
Anyway, I have a Dell 640m (...
I have a 2003 Small Business Server as my DHCP server and a Sonicwall TZ-180 serving as my router and wireless AP. My desired out come is to have the lan clients on one subnet (192.168.3.x) an...
I've got a new laptop and I get a wrong Ip adress when I connect to my wireless router. It should normally give me an adress in the 192.168.13.* range but I get an adress in the 192.168...
I have a Lenovo T60p running Vista Business. I automatically connect to my home LInksys router when the laptop boots up, but after a period of time (usually a couple of hours) the connection ...
I have to install a Cisco 2100 series wireless controller running 4.0 software
and 4 access points 1130 series IOS wireless LAN.
I am looking for information on design/configuration/insta...
I have a belkin 54g wireless router and a lynksys 54g wireless adaptor on a pc. a second pc is on a wired connection to the router. My problem is this, while internet operation is comparable o...
We are looking to set-up a Cisco 1130 AG that we want to set-up using WPA without an external Radius server. Is this possible with this device?
I want to setup a Cisco 1120G access point to have 2 SSID's, one for data and one for voice, with data being on VLAN 1 and Voice being on VLAN 5. I also want both of the SSID's to use a...
My computer cannot get a stable IP address. When I go into cmd prompt and type ipconfig I get the following error message:
An internal error occurred: the request is not supported. Please c...
I have a Linksys Wireless-N Broadband Router attached directly to my Netware network to provide internet access to a small group of laptop computers. The users now need to be able to log in to...
I have a new lenovo thinkpad from newegg, it will not connect to a network. I can boot into safe mode remove the hardware and then reboot. The computer then finds the hardware, installs it a...
My son has just bought a new SATA hard drive for his laptop (Samsung Q45) which replaced an old hard drive which ran on Windows Vista.
He has tried to connect to the internet via ethernet a...
I have been tasked with implementing a wireless network using Cisco equipment and need a little guidance as this has to be done by next week.
Background:
We have two sites, connected to a ...
Okay, experts...I need some help.
I currently have three Cisco Aironet 1242 WAP's that use PEAP authentication with a backend RADIUS server. This obviously works but I've been asked to add...
Scenario: Standard DSL-Router -- VISTA PC connected by CAT5 -- VISTA PC also has a USB WLAN stick -- Notebook with XP, using PCMCIA WLAN card. What we want to do is:
a) Set up a networ...
I have enabled enterprise WPA with a radius server authenticating. The wireless works fine when the user is already logged in, but once the user logs off and logs back in, an error is thrown ...
I'm trying to share an internet connection from a Mac Book Pro running Leopard, via bluetooth with a PC Laptop running Windows Vista.
Would anyone be able to help me achieve this?...
I can ping the access point just fine, but can't access the webgui at its IP-address.
I know theres an console port but i have not got a cable for that, but should i
not be able to access it...
I have a brand new wireless laptop and I am trying to get it to work on my work domain.
I have added it to the domain and it works fine when I used a cable and when it is logged into window...
I'm looking into setting up a long distance wireless bridge, 1.5 Miles minimum.
Anyone know where to start?
Dbb
I have a small office with about 40 wireless laptop users. We have three Cisco Aironet 1231 Access Points setup for signal distribution and load balancing.
To help properly distribute cove...
I have an Orinco Proxim AP-600 v2.5.5(1070) SN-04UT20560330 v3.0.4 wireless Access point. I also have one MS 2003 IAS/RADIUS Server I use to authenticate my CISCO VPN clients. I do not have ...
Hi, My laptop should in theory connect automatically to a wireless network/internet connection as soon as the laptop is in range. The problem is it doesn't, all it does is pick up the networ...
Hi!
I have a D-Link wireless router.It will slow down the internet connection.How do I know that?When I tried connecting the ADSL Modem direct to my home PC,the speed is on par with the pac...
I have bought 2 x Edimax EW7209APG Access Point so that I can extend a wired network for some remote clients to access the network wirelessly. I have connected the access point via Cat 5 and ...
