Time Tested WLAN Solutions: 76 - 100 of 210
I  have a home network with a PC connected by LAN and a laptop connected by wireless. I have tried to connect a second laptop to the network but without success. I am using a Netgear WG111v2 U...
I have a Cisco Aeronet 1200 access point and I'm trying to set up wireless on a MacBook running 10.4. Do I need a driver or something?
A freind of mine manages a furniture store and he asked me to setup a small network for him.  I got an off the shelf router and switch and some network cables.  Nuvox came over and setup a T1 ...
I am trying to get a Dell Inspiron Lap Top to talk to my Dell desktop by wireless connection. I am using a Netcom NB5 Plus 4W Wireless router and a NetGear USB 2.0 WG111 adaptor which I was to...
I have purchased a new P6860 Gateway, running vista home premium, sp1 I have an existing netgear rangemax wnr834bV2 wireless router as part of the network it uses 64bit WEP with a MAC filt...
I have a Verizon Mobile Broadband card that I use on my Vista laptop while traveling.  Sometimes, I'm accompanied by a collegue who needs internet access on their laptop.  Is there a way for m...
I am working on a Cisco Cat 4503.  I did a password recovery and now the switch acts as through there is no config on it, it resets to consule mode.  How do I get it to reset to the config tha...
Hi guys I have access point 1242 , I have setup with  2 Radius server , both primary and secondary, now my Access point which is cisco 1242 does not accept this command ... where as this ...
I have a problem obtaining ip address via wireless on my laptop. My pocket PC works on same wifi so I think the problem is the laptop. Firewall is off. Same problem is present with 2 seper...
In my site I have 4 3com 2750 access points covering 46,000 square feet of space,  all connected to a 3com wx1200 managed switch. When the wireless network was implemented there was no site su...
hi im new to this wireless "scene" i would like to know a few things when extending the range of a wireless network. im using an smc ezconnect wireless ethernet bridge that supports acces ...
I am able to connect to the net via an ethernat cable through a LAN but unable to connect to a visible network via wireless connection
I would like to connect a Roku Netflix Player to the internet via a cable connection.  In a different part of my home, I am running a mixed wired / wireless network using a Linksys Wireless G ...
Hi all, I am a bit confused about the 802.11 frame size and how it changes when applying WEP and WPA. Unencrypted 802.11 frame: header    |   data          | FCS (30)           (0-2312...
We have Cisco Aironet 802.11 a/b/g wireless PCI adapters running on XP boxes.  We need to connect to a wireless system using EAP-TTLS/PAP.  This is no problem if we disable the Cisco wireless ...
Hi, There are 2 houses, one in the road and the second in the top of a hill.  The one in the road has Internet broadband connection, while the house in the top of the hill does not. I fa...
I have my Dell Inspiron 1501 set up for dual boot to Windows Vista and Debian Linux. Everything is OK except one wireless connection to Linux. The Windows connection works. With Linux it usual...
Internally I have a proxy server for filtering etc.  I have setup my firewall to have a public IP address to use that proxy.  The goal is to "give" my remote users that proxy for filtering.  I...
I was called out to a site where there are 3 PCs, 2 Notebooks and 1 HP 7410 Officejet connected to a BTHome Hub 410D. One of the PCs is running Vista Ultimate. The others are running Windows X...
We're in a crowded manufacturing district.  Neighbors' wireless networks are visible on our WinXP Pro machines.  I want ONLY our internal network to be visible, so that our employees don't try...
I have a second laptop on my home wireless network that was functioning fine until I needed to do a system restore.  After that I received this message at boot: "Another wireless LAN utility i...
Dear All, I visit to different offices and clients places.  Everywhere I have to manually configure the Wifi details in my laptop along with the IP Nos, DNS Nos. to access internet & locan ...
We having four wireless access point each in each floor. I want to know we can use the same SSID  for all the four Access point. All the four access point will be connect in same subnet. An...
Security is always a major concern , especially with the wireless network being implemented. What measures will b e taken to increase the level of security on a wireless office network?
I am currently running a Win2k3 network with 3 Cisco 1130AG AP's connected to it. Currently the AP's are setup with defaults other than renaming the SSID's etc. Now, the 3 AP's are connected t...
