hey experts!
i have one question! can i use 2 internet connections on the same computer ????
which means can i use for example an internet connection for MSN, internet explorer,.... in a...
We have a client that wants us to install a wireless network for them. they will only need 2 or 3 access points to cover the entire building.
I would like to set them up to have 2 SSIDs, o...
Does anyone know where to find a download of the Cisco Software version 4.1.x for a 2000 series Wireless LAN Controller? We are currently at 4.0.219.0, and we have a huge number of WPA MIC err...
Hello Experts. I keep having the following problem. I have a laptop with vista business. I use a wireless connection to connect to my office network and internet. Whenever I add a dial u...
We recently had a 160 AP Cisco Wireless network installed at our site. The vendor only allows the access points to use channels 1, 6, and 11. Because these channels dont overlap. The networ...
Hi All
I got the following 3..actually 4 wirless routers
DL624 From DLINK
wrt54gl From Linksys
wrt54gs From Linksys
A SMC wirless router with WDS
I need setup two of those wirless ro...
Hi Experts,
I have a Billion Router 5100 wireless adsl router and for months its been great. I have 4 computers which connect to the router wirelessly. During the last week i noticed that i...
Hi guys
I am having a problem connecting my laptop to my wireless network at home, it connects fine, but with no internet except for skype. On other networks through wireless, I get interne...
Im so tired of these Intel Wireless adapters in laptops from Dell and Lenovo ThinkPads.
So many angry users and customers having troubles with the laptops I have installed for them. Some of...
Hi there, I am supporting a small wireless LAN. There are 5 PC connected at any one time, they are all set to obtain IP settings via DHCP on the Router/WAP/Switch.
The customer replaced a P...
I am very new to networking and I am attempting to set up a wireless network with the following components:
1. PC running Vista with a printer (I would like to share this with the other comp...
I am looking to deploy 14 Cisco light weight wireless access points at a WAN connected site (T1). I was considering the 2000 series WLAN controllers. The Cisco specs indicate that the WAPs do ...
We have a wireless bridge between two buildings. The main site has a DC providing DHCP services, but any clients on the remote side of the wireless bridge (using Cisco Aironet 1310 units) are ...
I have 12 Cisco Aironet 1200 Series Wireless Access Points mounted to the ceiling with 2 Air-Ant1728 2.4GHz., 5.2dBi Omnidirectional Ceiling mount antennas attached to the device and deployed ...
I have a Nokia N80 mobile with wi fi capabilities and a Netgear DG834G router for my ADSL connection . The problem is that my ISP prefers PPPoE connection and my router automatically sets the ...
Hope I can find a resolution here.
I was reading previous threads on accessing lan from wlan, while they helped.
The wireless clients can only access resources using ip address.
Is th...
Hi Experts,
I initially set up my cisco wireless ap on a network where I have several vlans, the config works great. I have been asked to ship one of my ap to another site where they do no...
I have set up my wireless connection on my HP pavilion laptop. It works fine until I reboot, I then have to manually open the wireless connections and reenter the SSID to get it to connect aga...
I have two cisco 1230AG's setup as basic access points and one setup as a workgroup bridge. In all the cisco examples of how a WGB works it shows the WGB access point plugged into a switch and...
program for limit traffic ip and p2p with windows
I want to konw one program for limit traffic the ip and p2p.every user can take the same
Hi experts,
I know that this question has been asked several times, but I couldn't find some specific answer to my issue. I have on one side: one PC (PC-A) running windows XP connected thr...
Greetings,
We have an issue with a message that is being listed in the Event log. I believe it stems from a device roaming outside of the of the AP it was associated with. The message is as f...
I have a workstation with wireless network connection - the wireless gets a good signal but it constantly drops its internet and network connection - is it related to IP stuff? Is there a list...
Bloomberg is failing to connect on Vista. The firewall/av is disabled. I receive the error SSLHandshake Failed rc:-6992.
The problem occurs on the 3G modem. Using the same modem on XP it wor...
I currently have a small network running Windows systems. I have a Cisco PIX running as the DHCP server for all workstations. I am adding a wireless router to the network and thought of keep...
