Time Tested WLAN Solutions: 151 - 175 of 210
Hello, I have a Cisco Wireless controller that I have trouble configuring. It has a default IP of 192.168.1.1 which I am able to connect to via the web interface. I then follow the configur...
I have a wireless network setup at home. The only security feature enabled on my router is Mac address access control. No WEP or WPA is enabled. I would to know if someone can use my wifi sign...
I am new to WiFi and been delaying implementation due to all the security issues I've heard and read about. Now I've been tasked to install a WLAN. I Just purchased a Cisco Aironet AP: "AP1242...
I have a lenovo laptop.It came with windows vista premium installed in it.Recently i changed my operating system to windows xp.I got everything working right but the wireless driver is not wor...
Due to the lack of response and my recent efforts, I am revising my question. I have had RADIUS working, but inconsistently. I believe I need assistance in understanding how to do the certific...
I have a PC and Laptop both have XP Pro. I have bought TP-Link WN321G Wireless USB Adapter for Desktop PC. My Laptop also supports Wireless connectivity. After googling for a while I am ab...
Hello All Heres something that is taxing my brain. I have setup SBS2003, there are two NIC cards and the DHCP is enabled on the server and disabled on my Netgear Router. Ethernet connection...
I run a small office and have a cable modem which hooks to a router and then to my switch. I need a backup for when the cable goes down.  I have a laptop with a broadband wireless access. ho...
I configured my Cisco AP 521 using the web assistant.  however I'm unable to bring the Radio0-802.11G interface up.   I tried to go into the interface configuration an enable the interface, ho...
I have a Cisco 1200 Access Point.  We use make address filtering.  All the Mac address that I have entered before today are still working but I can't not enter new ones. The error that I reci...
I would very much appreciate any help with this issue. Basically, I have a Samsung V25 Laptop with built-in Wireless Card. I have also got a Belkin Wireless Router - "ADSL2+ Modem with Wire...
I needed to upgrade a number of computers to work with our new wireless in the office which uses WPA2. Most of the computers did not have the WPA2 option already available so I had to install ...
Hi Experts! I have been struggling to get a Netgear DG834G to succesfully pair up with 2 WG602s to extend a wireless network.  I have spent ages on the phone with support but they just ain'...
I have SMCWPCIT-G PCI wireless PCI adapter running on xp, sp3 giving error smcwpcit.sys cause a error shutting system down to prevent damage to system. Something like that. Has anyone seen t...
Hello Experts, I've been getting this message recently and not sure how it came about and not sure how to fix the damn thing ! The message is 'Re-enter Credentials'  but when the user en...
I need a select set of workstations to act as if they were hard wired. These are not laptops but desktop PC's with Linksys wireless NIC's. I need them to be authenticated by the LWAPP/WLC and ...
I have a DLink DWL3200 AP which is set up with 3 SSID I have a problem with WiFi handsets I am running as thet keep dropping off when you look at the client info it syas the SSID is in Power S...
Hey all, I am trying to configure a new cisco 851w router for a small business. I am experiencing an issue where the wireless users on the same Vlan, Bridge, and SSID are not able to ping ...
I have 12 PCs hooked up in a peer to perr network. One of the PCs is a repository for backup of PC images. All PCs on the network have Windows 2003 XP PRO as the operating system.  When I back...
Hi All I am about to upgrade a network of 20 local clients, 3 laptops and 12 remote Terminal Server users. The upgrade involves migrating (swing migration) from the current SBS server (P4 S...
I'm currently running a WiFi network using Cisco Aironet 1200 APs  IOS 12.3(8)JA2.  I currently have only 1 SSID setup using MS PEAP and self signed certificates. I want to configure a gues...
Hey all. Tricky situation this one. I will try and be as accurate and as coherent as possible. I have a clients machine, No backups of stuff on their laptop (GRRR!), Tried fixing their WiFi...
Hi Everyone:        I am curious about the meaning or significance of the subnet mask number of 255.255.255.0.  This number seems to always be static in both home wired and home wireless ne...
Hello Experts.  I am part of a domain at my office and use the wireless connection on my laptop to connect.  I also have a portable broadband access modem which I use at home.  I have brought ...
I have a Billion 7404 VGPM ADSL Wireless Modem connected to the Internet and I want to connect to that a Netgear 834GT via cable to extend the range of our Wireless network The IP of the Bi...
