I have loaned an AIX Power Machine using the Virtual Loaner Program of IBM. My Task is to install WebSphere Application Server 5.1 on AIX. I tried the following Command:
"./LaunchPad.sh"
AIX 5.3 64bit
I am having issues with backing up my Oracle Binaries on my Oracle Home prior to
upcoming upgrade.
Of course the overall directory structure is over 2GB.
I have tried...
i still dont understand the significant of export volume group and import volume group.
Can someone tell me the scenario. i have read the ibm study guide it saying because you want move to ...
I have vulnerability issue here.
The server running on AIX 5.3
The question is ..
How to Configure the LDAP server so that it does not allow NULL BINDs.
Thank you
I'm running AIX 5.2.
How to convert JFS to JFS2 for
1. rootvg
2. uservg
Can provide the steps and command involve.
Thank you.
We recenlty changed out WAN connection to remote locations from a T-1 point to point to VPN over a broadband cable connection using static ip's. We route through a Cisco 1800 series router on ...
Hi gurus,
I have a problem with oracle database 10g running on AIX 5.3.
the Oracle halted and i can not log on to shut it down and restart through sqlplus.
So i have to restart the AIX ...
Logging into our AIX systems is sporadically very slow (ie - minute(s) instead of 2 seconds. After debugging our login scripts, I've come to think that this is a network issue or related to a...
I have a text file that contains a Form Feed/Line Feed (FF/LF) combination, and I want to convert all of those to just a Form Feed. It's sounds bloody simple, but for the life of me, I can't g...
I'm still pretty new to the Aix world and have the following questions for everyone. What are the hardware requirements for Aix 5.3 and how do you find your current system information on a Aix...
Hi everyone. I'm trying to install gcc on aix 5.1 and I'm getting the following error:
#rpm -i gcc-4.2.4-1.aix5.1.ppc.rpm
error: failed dependencies:
info is needed by gcc-4.2.4-1
I am trying to upgrade my IBM P series server AIX 5.2 to Technology Level 10 SP2 from Base version. For TL 10 SP2 we need to upgrade first to TL 10 SP1 then SP2, I have successfully done the u...
I'm running aix 5.3 ml 5
I have one uservg that has 2 hard disks ( hdisk1 and hdisk2) inside it.
hdisk1 has error reported and need to be replaced.
in hdisk1 has all logical volume ...
I am updating to 5300-07 Service Pack 3 from 5300-05-01 and was wondering how long the update could possibly take. the download is about 2GB in size.
Also is it ok to go from my current le...
My script will be run with filename.csv as argument. How to get the filename ".csv" without extension inside script?
How can I configure my AIX 5.3 to use NFS over TCP? OR how can I determine wether it is using TCP or UDP. By the way, we are using Wndows 2003 as our NFS server and it is used as a hom...
I am familiar with AIX COBOL cobrun "program name". Is there a different command for running a db2 program? (The program has been bound successfully.)
My SQL return code is -1024 when I try...
I need help resetting the file permissions on a directory (unix, AIX 4.2). Originally, the directory's permissions were:
drwx--S---
The permissions on the directory got changed to...
I have a Nagios server up and running and have been successful with using the nrpe addon in Linux to monitor things like CPU and disk on a remote server. However we would also like to monitor...
I have an RS/6000 H80, running AIX 4.3.
I had two 9GB SCSI disks (hdisk0 and hdisk1) running mirrored (I think via mklvcopy). hdisk0 started reporting that it was marking physical partitions...
I got a new job in a mostly AIX shop. I heard that the servers are running in a frame. What is a frame? Is it AIX specific? Is it IBM server specific?
Thanks.
I have a customer running a BBX Pro5 application that seems to run too slow for the machine they have. The machine is an IBM P630 running AIX 5.3 with 4 Gig RAM and lots of disk. The problem...
Hi
Recently am receiving errpt errors relating to a dodgy hard disk - As such I was hoping to mirror the rootvg and then replace the disk. Added a PV to the rootvg VG and ran the mirror th...
Our servers are in AIX. Can you please let me know step by step, how to assign multiple group to a directory.
Say the Directory name is Test.
I want to have
Grp1 having read permission...
Is it necessary to uninstall and reinstall Swift Alliance Gateway when adding a new BIC?
What are the steps in adding the BIC?
