// AIX 5.2
// under smit user,
What is the ramification of changing Soft DATA segment to -1?
i.e.
from
Soft DATA segment [262144]
to
So...
Could anyone kindly assist, I would need a unix command to list a count of the number of files in a directory.
ls - <which parameter> ???
Dear experts,
I would like to know as a regular unix user, how what commands can get the information of AIX 4.x and 5.x system
CPU clock speed (in MHz or GHz),
memory size (in MB or GB...
Experts,
We have AIX 5.3 running on a standalone box with 4 GB RAM.
From past couple of weeks the physical memory has been shooting high, 100% many times and the system is paging highly.
T...
I want to list the top processes using CPU and memory. The "top" command is not working on my AIX. You know I am not an admin. Thanks.
Jirong
Hi All,
Our system is AIX 5.1.
1. I wrote a srcipt to tar only FOUR directories:
tar -cvf /dev/rmt0.1 / >> /logs/coldbackup
tar -cvf /dev/rmt0.1 /usr >> /logs/coldbackup
tar -cvf /...
I am trying to install Samba on my AIX 5.3 box.
Although Samba comes pre-installed on most
of the other OSs this is not the case here
(unable to find smb.conf file)
Can anyone tel...
I've been asked to trace a process that we've been having problems with on our production Unix AIX server. I've never heard of the truss command until a few days ago. How do I trace a process ...
Hi All,
Below is my script to remove carriage return to convert DOS to unix file format.
#!/usr/bin/ksh
if [ $...
I need the command to copy an entire directory and all it's contents from one UNIX server to another by using FTP. Any help would be appriciated.
I am looking for an easy script that I can use to copy all of the files and folders in a directory on one server to a directory on another server. The script will be run on the destination and...
Generally the ulimit settings for memory are set at 32 GB. (ulimit -a or cat /etc/security/limits will show).
If needed can these memory setting for all users be changed to infinity? O...
I have one for all of you AIX guru's out there -
We have recently taken on a vendor who needs FTP-Put access to a directory on our UNIX server in order to send invoice confirmation files t...
I've got a AIX 5.3 Server which has applications that generates out bound email. This server is not our email server. The problem is that I need to rewrite the from address. I have a local ...
I have installed AIX 5.2. But it is not having ssh. than how to install SSH on AIX 5.2.
I have gone throught this but i have not find any SSH pakages
http://unixarticles.com/artic...
After much testing of an application which was consuming ungodly amounts of memory, we have determined that every time the product uses it's data cache, the cache is left in memory and never c...
Hi All,
Iam running a script in AIX which calls ant utility. The script terminates by saying
ant: 0403-006 Execute permission denied
I extract a util directory from an ear file and set t...
Is it possible to stop and start crontab daemon?
If yes, how do you do that?
thx much
Greetings,
This ia a variation of a question I posted and received one answer to earlier. As I thought about it, I realize I left oout one very important piece of info from my original que...
snider:stmil1:/cern/d_stp> ls -al
ls: .: The file access permissions do not allow the specified action.
total 0
ls: .: The file access permissions do not a...
In a RS6000 with AIX, I need to change the default gateway. I used smitty but after changing the value, the old IP comes allways unchanged. What am I doing wrong?
What is the best way to upgrade it to 5.2.8 and donwload/get all of these filesets?
What is the URL that I need to get them if all of them aer downloable from IBM?
# oslevel -rl 5200-08
F...
I've been given the task of creating an FTP script that will copy files (created by our ERP app) from one directory to an archive directory, send them to a remote FTP server and then delete th...
Hey,
There is an hba card that is plugged into an IBM p Series server. I need to find out the wwpn of the hba installed on that server. I want to verify it with what the switch indicates. A...
As I was reading some information about IBM AIX, I found that it's a unix operating system. I do know some unix commands while I was using sun solaris, however what is the difference between I...
