Over 40 Experts attended the first Annual Core Conference! Take a look at what happened throughout the week...
2008 Core Conference
Time Tested OpenBSD Solutions: 1 - 25 of 36
Greetings, Environment: Two openbsd 4.0 server environment --  main.mail.server in DMZ, another in firewalled LAN.    firewall denies SMTP from LAN except to DMZ mail server.   Sendmail...
So I have openbsd 3.7 with kde installed on a amd64.  In particular, the motherboard is a gigabyte GA-k8vm800m. The video is on the motherboard.  The best resolution I can get is 640 by 480 as...
Hello How do I set the JAVA_HOME environment variable I am using a virtual Free BSD server, which means that I don't have root access, only telnet/SSH access. The hosting company in...
i modified my pf.conf file using vi whats the command to save the changes that i have made and why does it say that the file is read only can someone give a step by step help all i need ...
Hi all, i'm a beginner with Freebsd OS. And now i'm starting to learn and know it deeper. I wanna know, how to install a package if the file with .tar.gz extention.
Hi, I'm currently working on last OpenBSD release (4.1), to set up a BIND DNS server. Installation is ok, but OpenBSD install bind 9.3.4. I'd like to upgrade bind to 9.4.1. There is no...
HI, I have a device that configurable thru serial port and I can use Windows HyperTerminal to communicate it with my PC serial RS 232 port.  Now I move this port to attach to an UNIX machin...
Hello folks, Newb question here.  I'm trying to clean up some stuff on an OpenBSD 4.1 build.  I've checked the man pages for rmdir, and this is all it contains: # man rmdir RMDIR(1)    ...
I want to download FreeBSD, OpenBSD and NetBSD and burn it to CDs at my friends place. After that I want to bring it back to me and install it on my computer. What do I need to burn and how do...
Hello, Experts! I am running small OSPF network on my OpenBSD routers for client traffic management with trivial "security" policy - static arp entries for single computer which is connecte...
I noticed yesterday that when I run an NMAP against the external interface of my OpenBSD firewall it shows ports in the "filtered" state, that I know nothing about.  In the past it would only ...
hi, is there a way that i can restrict the number of concurrent logins using active directory and group policy? thanks. -m
Hi, I have a Hard drive which has is loaded with BSD UNIX and some software.This disk is used for some hardware appliance.I want to make a disk clone of this hard drive for my Disaster recove...
Can someone show me how to : - make a complete mirror of my freebsd box to another freebsd box (kind of moving HDD) over LAN (highspeed) Thanks
I have 2 networks I need to join via a router. interface 1 : 10.69.69.2/8 interface 2 : 192.168.0.200/24 I set net.inet.ip.forwarding=1 in sysctl.conf this doesn't work at all. I'...
Hello Using Jalbum (http://www.datadosen.se/jalbum/) and when I try to access the the Java Bean I get this error. org.apache.jasper.JasperException: /usr/local/j2sdk-1.3.1/jre/lib/i386/l...
Hi, I'm writing a perl script for firewall configuration and I need a way of determining my ip address into a variable. Ie: The ip address of the person telnetted / ssh'd into the system...
Hi, I'm running OpenBSD 3.3 with the base install of XFree86 4.2. I'm trying to set up xdm from rc.local, xdm-config, Xaccess, etc...to enable remote login via ssh/XDMPC using Xwin32. The loc...
Hi all,   I am a newbie for BSD, I already have linux installed and I was thinking of installing BSD, but I am confused since I dont know which one is better FreeBSD or openBSD. Can anyone pl...
Hi all. Im having problems allowing the kernel to let me include my own ip header. I am writing a network/firewall and protocol analysis tool for my work. Running on x86/OpenBSD 3.3 plat...
Hi, I have inherited a FreeBSD 4.5 (i386) box running qmail and vamailarmor.  After shutting the box down recently for a LAN upgrade it started complaining about disk space..  The error mes...
I have an OpenBSD firewall and need to reconfigure the network settings "live" on the machine.  From the command prompt I entered: ifconfig em1 169.237.245.155 255.255.255.240 the system...
I'm configuring an OpenBSD (version 4.3) as a dedicated firewall.  I have 1 gig in RAM and a 4 gig compact flash card.  I want to store 31 days worth of logs.  "Building Firewalls with OpenBSD...
Hi I have a strange problem on my OpenBSD box. localhost seem to be mapped to an incorrect ip address. (or for some other reason) # ping localhost PING localhost.rby.se (85.228...
Can anybody tell me how can I remove the bootblock from a HD that has had NetBSD or OpenBSD previously installed on it? The problem is that the boot block is installed into the MBR and no ano...
