I want to install unixODBC-devel-2.2.11 and all it's dependencies
Can anyone give me the rpm for this
I seem to be missing SWAT from my redhat linux system as the /etc/inetd.conf is not there.
So I obtained a copy of samba-swat-2.2.7a-7.9.0.i386.rpm to remedy this and tried to install when...
I am trying to use this tutorial (http://kb.mediatemple.net/questions/233/Using+%28remote%29+MS-SQL+databases+with+PHP+on+a+%28dv%29) to install FreeTDS on my server to be able to connect to a...
I have OS setup in iso file but it is non-bootable and I want to convert this iso file in bootable.
I am having MagicISO software. Which software required to do so?
Thanks in ad...
We have a requirement to provide msi for users to run, which will copy files to c:\windows logged as admin as this is locked down for users credentials.
I need help in creating msi using vi...
I'm attempting to install ImageMagick on CentOS 5. Unfortunately, the latest version of ImageMagick available in the yum repositories is 6.2.8 and I need 6.3.5 or later.
I attempted to bui...
How to create RPM packages from scratch in Redhat Linux.
I am trying to build rpm from spec file but I am getting following error while building
"error: Bad exit status from"
Please help me to resolve this error.
Thanks in advance.
I am trying to install openNMS via yum. Have run command adding their repository, displayed text shows output. Anyone have idea on error received at bottom? Running Centos 5.2
yum instal...
i've installed a new server, and i can't install PINE.
it failed in : libldap.so.2 is needed by pine-4.64-1.i386
and i can't find libldap.so.2 ANYWHERE
i googled it a bit, and i tryied to...
I'm trying to write an rpm spec file to handle upgrades of a package, currently rpm --erase followed by rpm --install is necessary whereas I want to just do rpm --upgrade.
This is on fedora...
Can someone provide instructions on how to install cURL support with php 4.4.4 on already functioning virtual dedicated server from godaddy? I have many sites functioning on the server so I ca...
I want to calculate difference (no. of days) between two dates in excel. I want to know which functions & how to use it.
HI,
Can any one tell me how to resolve the dependencies while installing any rpm? I am using RHEL5 (unlisenced). so cant run yum command. Before RHEL5 i was usign --aid parameter and if the...
I'm trying to upgrade Autoconf (because of some dependencies I need Autoconf 2.6 or higher and I currently have 2.59. I tried "yum upgrade autoconf" but get "No Packages marked for Update". ...
I need a piece of advice. I have a piece of software that in made up of a runnable JAR file, and a directory structure with supporting files. I also have a script that needs to run the first t...
Currently, I've got a Fedora Core 6 server with openssl-0.9.8b, but it seems doesn't working with paypal, so I want to upgrade openssl-0.9.8b to openssl-0.9.8g. So anyone can help me to do it?
Hello
I am using CentOS 4 and am being prompted for the elinks package which is a dependancy.
Can anyone tell me which application/s I would install to install elinks ?.
Thanks in adv...
My RHEL5 box broke itself during a yum upgrade. The root disk was full prior to running, and the upgrade broke badly.
Now yum is broken along with samba, ssh, xwindows and god knows what els...
I am searching for a suitable readline package for my SuSE virtual server. I am using this server: novell.com > http://www.novell.com/documentation/sles10/esd/di_sles10_vmware.html.
ya...
This is interesting, I am running CentOS 5.2 64bits. I removed YUM and RPM by accident, any idea how to install rpm or yum on the server again?
I did a mistake by using, "yum remove sqlite ...
rpm install php-domxml I try that command but it not work please help and how can i update that package
I have a single, relocatable binary RPM that I want to install/uninstall to multiple base paths on my system (I have many developers mounting their target filesystems on the same server via NF...
Here is what I am going
540>rpm -ivh glib2-2.8.1-3.aix5.1.ppc.rpm
error: failed dependencies:
gettext is needed by glib2-2.8.1-3
But I do have gettext installed
541>which gett...
