Beginning OOP: How to implement and call Interfaces with a conflicting method name in same Class
AID: 7330
  • Status: Published
1550 points
  • Bygopaltayde
  • TypeTips/Tricks
  • Posted on2011-09-03 at 07:04:09
This article is for Object-Oriented Programming (OOP) beginners.
An Interface contains declarations of events, indexers, methods and/or properties. Any class which implements the Interface should provide the concrete implementation for each Interface member. In C# multiple inheritance is achieved with the help of Interfaces.
Therefore, if the Development Team is large or 3rd-party vendors are involved, then it may possible that two team members may end up creating two different Interfaces with the same method name. Consequently, as a developer you may have to implement both these Interfaces in one Class.
Scenario: So let’s assume that –
You have two different Interfaces let’s say ICustomer and IVendor. Both the Interfaces have a method with same name let's say GetData().
GetData() from ICustomer would return the list of customer names while GetData() from IVendor would return the list of vendor names. In the data access layer, a single class CompanyDAL implements both these Interfaces.
See attached Code Snippet for Interface definitions –
using System.Collections.Generic;
namespace ExplicitInterfacesSite
    // Simple interface for Vendor class
    public interface IVendor
        // Return the list of vendor names
        List<string> GetData();
    // Simple interface for customer class
    public interface ICustomer
        // Return the list of  customer names.
        // This function name is conflicting with IVendor's GetData.
        // Another method, which is not conflicti
        string GetCustomerAddress(int customerId);
Solution:
While implementing the Interface in a class, we must provide the concrete implementation to each of the Interface member. For non-conflicting Interface members, we can just write the member name and provide the implementation. But for any method which is common in both the Interfaces, the member should be implemented explicitly in the class.
By explicit, I mean the method name should be prefixed with <InterfaceName.>. In our case it is like IVendor.GetData () or ICustomer.GetData().
See Code Snippet –
    public class CompanyDAL : IVendor, ICustomer
        #region IVendor Members
        List<string> IVendor.GetData()
            // Implement your logic to get the list of Vendor  Names
            return new List<string>() {"Vendor1", "Vendor2", "Vendor3"};
        #endregion
        #region ICustomer Members
        // This is how we should implement the conflicting method, explicitely
        List<string> ICustomer.GetData()
            // Implement your logic to get the list of Customer Names
            return new List<string>() {"Customer1", "Customer2"};
        // No need of Interface.MethodName as there is no conflict.
        public string GetCustomerAddress(int customerId)
            return "Dummy Customer Address";
        #endregion
And when we want to call that method, we need to typecast the class object to the desired Interface.
I have added an .aspx page in the project to demonstrate this. It just prints the list of vendors and customers.
See the attached Code Snippet –
using System;
    public partial class _Default : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
            // Create the object
            CompanyDAL expliciteObj = new CompanyDAL();
            // Can directly call method, whose name is not confliciting
            expliciteObj.GetCustomerAddress(1);
            // Cast the object to the interface first and then call  the conflicting method.
            // Here we are calling the GetData() method of IVendor class.
            List<string> lstVendors = (expliciteObj as IVendor).GetData();
            Response.Write("Vendor List:</br>");
            foreach (string vendorName in lstVendors)
                Response.Write(vendorName);
                Response.Write("</br>");
            // Here we are calling the GetData() method of ICustomer class.
            List<string> lstCustomers = (expliciteObj as ICustomer).GetData();
            Response.Write("Customer List:</br> ");
            foreach (string customerName in lstCustomers)
                Response.Write(customerName);
Let's look at the below code line carefully –
I first typecast the expliciteObj to the Interface type, and then called the conflicting method. By doing this we are able to remove the conflict/ambiguity in the method name. This would return a list of string. It should contain below strings (vendor names):
"Vendor1", "Vendor2" and "Vendor3".
The same way in the below code line –
expliciteObj is first converted to ICustomer and then called the method GetData. This call would return a list of customer names. In our case it should be:
"Customer1" and "Customer2".
Summary: In the above article I tried to explain how to achieve multiple Interface inheritance in C# and how to handle conflicting methods present in more than one Interface. I hope you will enjoy reading this article. Waiting for your feedback.
2011-09-03 at 07:04:09ID7330
OOPs
explicitly Implementing Interfaces
Casting to interface
C# Programming Language
Views
973
Add your Comment
Please Sign up or Log in to comment on this article.
Join Experts Exchange Today
Gain Access to all our Tech Resources
Get personalized answers
Ask unlimited questions
Access Proven Solutions
Search 3.2 million solutions
Read In-Depth How-To Guides
1000+ articles, demos, & tips
Watch Step by Step Tutorials
Learn direct from top tech pros
And Much More!
Your complete tech resource
See Plans and Pricing
Top C# Experts
  1. kaufmed
    566,376
    Sage
    500 points yesterday
    Profile
    Rank: Genius
  2. BuggyCoder
    240,764
    Guru
    10 points yesterday
    Profile
    Rank: Sage
  3. navneethegde
    158,560
    Guru
    0 points yesterday
    Profile
    Rank: Wizard
  4. CodeCruiser
    140,708
    Master
    2,000 points yesterday
    Profile
    Rank: Genius
  5. TheLearnedOne
    137,350
    Master
    2,800 points yesterday
    Profile
    Rank: Savant
  6. wdosanjos
    124,511
    Master
    3,500 points yesterday
    Profile
    Rank: Genius
  7. AndyAinscow
    107,357
    Master
    0 points yesterday
    Profile
    Rank: Genius
  8. Dhaest
    98,335
    Master
    0 points yesterday
    Profile
    Rank: Genius
  9. Idle_Mind
    91,914
    Master
    0 points yesterday
    Profile
    Rank: Savant
  10. tommyBoy
    90,068
    Master
    0 points yesterday
    Profile
    Rank: Genius
  11. nishantcomp2512
    89,000
    Master
    0 points yesterday
    Profile
    Rank: Wizard
  12. MlandaT
    86,553
    Master
    0 points yesterday
    Profile
    Rank: Genius
  13. Chinmay_Patel
    80,818
    Master
    0 points yesterday
    Profile
    Rank: Genius
  14. ddayx10
    66,538
    Master
    0 points yesterday
    Profile
    Rank: Sage
  15. anarki_jimbel
    66,132
    Master
    Profile
    Rank: Genius
  16. ambience
    63,764
    Master
    0 points yesterday
    Profile
    Rank: Sage
  17. ukerandi
    62,593
    Master
    1,000 points yesterday
    Profile
    Rank: Guru
  18. apeter
    60,772
    Master
    0 points yesterday
    Profile
    Rank: Sage
  19. JamesBurger
    60,305
    Master
    0 points yesterday
    Profile
    Rank: Sage
  20. sedgwick
    52,750
    Master
    1,600 points yesterday
    Profile
    Rank: Genius
  21. emoreau
    50,917
    Master
    0 points yesterday
    Profile
    Rank: Genius
  22. ged325
    50,311
    Master
    Profile
    Rank: Genius
  23. anuradhay
    49,977
    2,500 points yesterday
    Profile
    Rank: Guru
  24. techChallenger1
    47,638
    0 points yesterday
    Profile
    Rank: Guru
  25. mas_oz2003
    43,540
    0 points yesterday
    Profile
    Rank: Genius
Hall Of Fame
