Using an access 2007 database. There is a field 'contact' that has hundreds of names in it. There are many formats:
Mr. FirstName LastName
Mrs. FirstName LastName
FirstName LastName
FirstName LastName-LastName2
FirstName LastName LastName2 Jr/Sr
I want to automatically get them into 2 columns: firstname, lastname
First, I am going to strip out ALL Mr., Mrs., Ms. to make it simple. So I know the first token is FirstName and the REST is LastName.
How can I accomplish this?
I have a column in Excel that shows a full name, in the following format:
Lastname, Firstname Middlename
Some entries may have titles and/or suffixes as well:
Lastname <Suffix>, <Title> Firstname Middlename
Please help me extract the Title, First Name, Middle Name, Last Name, and Suffix into separate columns.
Full Name: John Smith
Assumption: Space delimits first and last names
Excel (full name in A1)
First Name: =LEFT(A1,FIND(" ",A1)-1)
Last Name: =MID(A1,FIND(" ",A1)+1,LEN(A1))
Access (full name in column FullName)
First Name: Left([FullName], InStr(1, [FullName], " ") - 1)
Last Name: Mid([FullName], InStr(1, [FullName], " ") + 1)
VB6/VBA (full name in variable FullName)
First Name: Left(FullName, InStr(1, FullName, " ") - 1)
Last Name: Mid(FullName, InStr(1, FullName, " ") + 1)
Full Name: Smith, John
Assumption: Comma delimits last and first names
First Name: =TRIM(MID(A1,FIND(",",A1)+1,LEN(A1)))
Last Name: =LEFT(A1,FIND(",",A1)-1)
First Name: =Trim(Mid([FullName], InStr(1, [FullName], ",") + 1))
Last Name: =Left([FullName], InStr(1, [FullName], ",") - 1)
First Name: =Trim(Mid(FullName, InStr(1, FullName, ",") + 1))
Last Name: =Left(FullName, InStr(1, FullName, ",") - 1)
Full Name: John James Smith
Assumption: Middle name may or may not be present
First: =LEFT(A1,FIND(" ",A1)-1)
Middle: =IF(ISERR(MID(A1,FIND(" ",A1)+1,IF(ISERR(FIND(" ",A1,FIND(" ",A1)
+1)),FIND(" ",A1),FIND(" ",A1,FIND(" ",A1)+1))-FIND(" ",A1)-1)),
"",MID(A1,FIND(" ",A1)+1,IF(ISERR(FIND(" ",A1,FIND(" ",A1)+1)),
Last: =RIGHT(A1,LEN(A1)-FIND("*",SUBSTITUTE(A1," ","*",LEN(A1)-
LEN(SUBSTITUTE(A1," ","")))))
First: Left([FullName], InStr(1, [FullName], " ") - 1)
Middle: IIf((Len(Replace([FullName], " ", "") - Len([FullName])) > 1,
Mid([FullName], InStr(1, [FullName], " ") + 1,
InStrRev([FullName], " ") - InStr(1, FullName, ",") - 1, "")
Last: Mid([FullName], InStrRev([FullName], " ") + 1)
First: Left(FullName, InStr(1, FullName, " ") - 1)
Middle: IIf((Len(Replace(FullName, " ", "") - Len(FullName)) > 1,
Mid(FullName, InStr(1, FullName, " ") + 1,
InStrRev(FullName, " ") - InStr(1, FullName, ",") - 1, "")
Last: Mid(FullName, InStrRev(FullName, " ") + 1)
First Middle Last | Last, Middle First
John Smith | Smith, John
John James Smith | Smith, John James
Dr. John Smith | Smith, Dr. John
Dr John James Smith III | Smith III, Dr John James
Rev. Dr. Martin Luther King, Jr. | King, Jr., Rev. Dr. Martin Luther
Elizabeth Marie Jones, M.D, Ph.D. | Jones, M.D, Ph.D., Elizabeth Marie
Elizabeth Marie Jones,MD,PhD | Jones,MD,PhD,Elizabeth Marie
Nancy Jones-Smythe | Jones-Smythe, Nancy
Option Explicit
Function GetNamePart(NameStr As String, NamePart As String, Optional UseMiddle As Boolean = True, _
Optional FirstMiddleLast As Boolean = True)
' Function by Patrick Matthews
' This code may be freely used or distributed so long as you acknowledge authorship and cite the URL
' where you found it
' This function relies on Regular Expressions. For more information on RegExp, please see:
' http://www.experts-exchange.com/articles/Programming/Languages/Visual_Basic/Parsing-Names-in-MS-Office-Visual-Basic-6-and-Visual-Basic-for-Applications.html
' This function parses a name string, and depending on the arguments passed to it it returns a
' title, first name, middle name, surname, or suffix.
' This function can be used in any VBA or VB6 project. It can also be used directly in Excel worksheet
' formulae and in Access queries
' The function takes the following arguments:
' 1) NameStr is the full name to be parsed. Its assumed structure is determined by the FirstMiddleLast
' argument
' 2) NamePart indicates the portion of the name you want returned. Valid values (NOT case sensitive):
' Title: "TITLE", "HONORIFIC", "T", "H", "1"
' First: "FIRST NAME", "FIRSTNAME", "FNAME", "F NAME", "FIRST", "F", "FN", "F N", "2"
' Middle: "MIDDLE NAME", "MIDDLENAME", "MNAME", "M NAME", "MIDDLE", "M", "MN", "M N", "3"
' Last: "LAST NAME", "LASTNAME", "LNAME", "L NAME", "LAST", "L", "LN", "L N", "SURNAME", "4"
' Suffix: "SUFFIX", "5"
' 3) UseMiddle indicates whether or not a middle name *might* be present in the NameStr. If True or
' omitted, the function assumes that a middle name *might* be there. If False, it assumes there
' is never a middle name
' 4) FirstMiddleLast indicates the order of the name parts. If True or omitted, the function assumes:
' <Title (optional)> <First name> <Middle Name (optional)> <Surname> <Suffix (optional)>
' If False, the function assumes:
' <Surname> <Suffix (optional)>, <First name> <Middle Name (optional)>
' Notes:
' 1) The function has a prebuilt list of Titles (see GenerateLists function below), which you can modify to
' fit your needs. The Titles string will be embedded in a RegExp Pattern string, so be sure to follow
' proper RegExp Pattern syntax
' 2) The function will recognize compound titles, as long as they are delimited by spaces
' 3) The function has a prebuilt list of Suffixes (see GenerateLists function below), which you can modify to
' fit your needs. The Suffixes string will be embedded in a RegExp Pattern string, so be sure to
' follow proper RegExp Pattern syntax
' 4) The function will recognize compound suffixes, as long as they are delimited by commas and/or spaces
' 5) If you are using True (or omitting) for FirstMiddleLast:
' a) It is always assumed that the first name has a single "word"
' b) It is always assumed that the middle name, if present, has a single "word"
' c) After the function has identfied the title, first name, middle name, and suffix, it assumes that
' whatever is left must be the surname/last name
' d) Thus, this function will process compound first/middle names incorrectly
' 6) If you are using False for FirstMiddleLast:
' a) It is always assumed that the last comma in NameStr delimits the <Surname><Suffix> block
' from the <Title><First name><Middle name> block
' b) Whatever is left in the <Surname><Suffix> block after the suffix has been removed is assumed
' to be the last name
' c) After the Title is removed from the <Title><First name><Middle name> block, if there is only
' one "word", it is the first name. If there are 2+ "words" and UseMiddle = True or omitted,
' then the last word is the middle name, and the rest is the first name
' d) Thus, this function will process compound middle names incorrectly, and may erroneously think
' a compound first name is a first name and a middle name
Dim Title As String
Dim FName As String
Dim MName As String
Dim LName As String
Dim Suffix As String
Dim RegXReturn As Object
Dim NameArr As Variant
Dim Counter As Long
Dim StartsAt As Long
Dim TitleLen As Long
Dim LastComma As Long
Dim Part1 As String
Dim Part2 As String
Static Titles As String
Static Suffixes As String
Static RegX As Object 'holding as a Static variable to improve performance
If Trim(NameStr) = "" Or Trim(NamePart) = "" Then
GetNamePart = ""
Exit Function
End If
If Titles = "" Then Titles = GenerateLists("Titles")
If Suffixes = "" Then Suffixes = GenerateLists("Suffixes")
' remove leading and trailing spaces
NameStr = Trim(NameStr)
' instantiate RegExp if needed (static variable, so it will remain in between calls)
If RegX Is Nothing Then
Set RegX = CreateObject("VBScript.RegExp")
With RegX
.IgnoreCase = True ' case insensitive
.Global = True ' finds all matches, not just first match
End With
End If
' Determine structure of NameStr
If FirstMiddleLast Then
' NameStr is structured <Title (optional)> <First name> <Middle Name (optional)> <Surname> <Suffix (optional)>
' Set Pattern to look for titles at beginning of NameStr
RegX.Pattern = "^(" & Titles & ")\.? +"
' Look for titles. Use Do...Loop to allow for compound suffixes, as in "Rev. Mr. Arthur Dimmesdale"
Do
Set RegXReturn = RegX.Execute(Mid(NameStr, TitleLen + 1))
If RegXReturn.Count > 0 Then
TitleLen = TitleLen + Len(RegXReturn(0))
Else
Exit Do
End If
Loop
' Get Title
Title = Trim(Left(NameStr, TitleLen))
' Adjust NameStr
NameStr = Mid(NameStr, TitleLen + 1)
' Look for suffixes. Use Do...Loop to allow for compound suffixes, as in "Alfred E. Neumann, PhD, Esq."
' StartsAt indicates where the suffix(es) start in the NameStr. Initialize to -1, indicating no suffix
StartsAt = -1
' Set Pattern to look for suffix at end of NameStr
RegX.Pattern = "(, *| +)(" & Suffixes & ")\.?$"
' Evaluate the NameStr. As long as a suffix is found in the portion evaluated, reset the StartsAt variable.
' When no more suffixes are found, terminate the loop
Do
Set RegXReturn = RegX.Execute(Left(NameStr, IIf(StartsAt > -1, StartsAt, Len(NameStr))))
StartsAt = RegXReturn(0).FirstIndex ' Recall that FirstIndex starts at position zero, not 1 !!!
Else
Exit Do
End If
Loop
' If a suffix is found, then grab the entire suffix
If StartsAt > -1 Then
Suffix = Mid(NameStr, StartsAt + 1)
' remove comma if applicable
If Left(Suffix, 1) = "," Then Suffix = Mid(Suffix, 2)
' remove possible leading space
Suffix = Trim(Suffix)
' adjust NameStr to remove suffixes
NameStr = Left(NameStr, StartsAt)
End If
' Ensure we have space delimiters for remaining NameStr
NameStr = Replace(NameStr, ".", ". ")
' Remove extraneous spaces
RegX.Pattern = " {2,}"
NameStr = Trim(RegX.Replace(NameStr, " "))
' Create zero-based array with remaining "words" in the name
NameArr = Split(NameStr, " ")
' First name is always assumed to be in position zero
FName = NameArr(0)
' Depending on how many "words" are left and whether middle name is assumed to possibly be there
' (UseMiddle argument), grab middle/last names
Select Case UBound(NameArr)
Case 0
'no middle or last names
Case 1
' first name and last name
LName = NameArr(1)
Case Else
' potentially first, middle, and last names are present
If UseMiddle Then
' position 1 is assumed to be middle name, and positions 2 to N the last name
MName = NameArr(1)
' remaining "words" are for last name
For Counter = 2 To UBound(NameArr)
LName = LName & " " & NameArr(Counter)
Next
' drop leading space
LName = Trim(LName)
Else
' assume no middle name, and all remaining words are for the last name
For Counter = 1 To UBound(NameArr)
Next
LName = Trim(LName)
End If
End Select
Else
' NameStr is structured <Surname> <Suffix (optional)>, <Title (optional)> <First name> <Middle Name (optional)>
' Find position of last comma
LastComma = InStrRev(NameStr, ",")
If LastComma > 0 Then
' Part1 will be <Surname> <Suffix (optional)> block;
' Part2 is <Title (optional)> <First name> <Middle Name (optional)>
Part1 = Trim(Left(NameStr, LastComma - 1))
Part2 = Trim(Mid(NameStr, LastComma + 1))
' Look for suffixes. Use Do...Loop to allow for compound suffixes, as in "Neumann, PhD, Esq., Alfred E."
' StartsAt indicates where the suffix(es) start in Part1. Initialize to -1, indicating no suffix
StartsAt = -1
' Set Pattern to look for suffix at end of Part1
' Evaluate Part1. As long as a suffix is found in the portion evaluated, reset the StartsAt variable.
Do
Set RegXReturn = RegX.Execute(Left(Part1, IIf(StartsAt > -1, StartsAt, Len(Part1))))
Else
Exit Do
End If
Loop
Suffix = Mid(Part1, StartsAt + 1)
' adjust Part1 to remove suffixes
Part1 = Left(Part1, StartsAt)
End If
LName = Trim(Part1)
' Set Pattern to look for titles at beginning of Part2
' Look for titles. Use Do...Loop to allow for compound suffixes, as in "Dimmesdale, Rev. Mr. Arthur"
Do
Set RegXReturn = RegX.Execute(Mid(Part2, TitleLen + 1))
Else
Exit Do
End If
Loop
' Get Title
Title = Trim(Left(Part2, TitleLen))
' Adjust Part2
Part2 = Mid(Part2, TitleLen + 1)
' Ensure we have space delimiters for remaining Part2
Part2 = Replace(Part2, ".", ". ")
Part2 = Trim(RegX.Replace(Part2, " "))
' Grab first/middle names from Part2
If UseMiddle And InStr(1, Part2, " ") > 0 Then
MName = Mid(Part2, InStrRev(Part2, " ") + 1)
FName = Left(Part2, InStrRev(Part2, " ") - 1)
Else
FName = Part2
End If
End If
End If
' determine function's return value
Select Case UCase(NamePart)
Case "TITLE", "HONORIFIC", "T", "H", "1"
GetNamePart = Title
Case "FIRST NAME", "FIRSTNAME", "FNAME", "F NAME", "FIRST", "F", "FN", "F N", "2"
GetNamePart = FName
Case "MIDDLE NAME", "MIDDLENAME", "MNAME", "M NAME", "MIDDLE", "M", "MN", "M N", "3"
GetNamePart = MName
Case "LAST NAME", "LASTNAME", "LNAME", "L NAME", "LAST", "L", "LN", "L N", "SURNAME", "4"
GetNamePart = LName
Case "SUFFIX", "S", "5"
GetNamePart = Suffix
Case Else
GetNamePart = ""
End Select
' destroy object variable
Set RegXReturn = Nothing
End Function
Function GetAllNameParts(NameStr As String, Optional UseMiddle As Boolean = True, _
' This function parses a name string, and returns a Dictionary object (Microsoft Scripting Runtime) with
' keys corresponding to title, first name, middle name, surname, and suffix. If a name part is missing from the
' full name, the Dictionary item associated with that key is a zero-length string. The keys are:
' Title, First, Middle, Last, and Suffix (not case sensitive)
' This function can be used in any VBA or VB6 project. However, it cannot be used directly in an Excel
' worksheet formula or an Access query
' argument
' 2) UseMiddle indicates whether or not a middle name *might* be present in the NameStr. If True or
' 3) FirstMiddleLast indicates the order of the name parts. If True or omitted, the function assumes:
' Notes:
Dim Title As String
Dim FName As String
Dim MName As String
Dim LName As String
Dim Counter As Long
Dim Part1 As String
Dim Part2 As String
Dim dic As Object
Set dic = CreateObject("Scripting.Dictionary")
With dic
.CompareMode = 1
.Add "Title", ""
.Add "First", ""
.Add "Middle", ""
.Add "Last", ""
.Add "Suffix", ""
End With
If Trim(NameStr) = "" Then
Set GetAllNameParts = dic
Set dic = Nothing
Exit Function
End If
With RegX
End With
End If
Do
Else
Exit Do
End If
Loop
' Get Title
' Adjust NameStr
StartsAt = -1
Do
Else
Exit Do
End If
Loop
End If
FName = NameArr(0)
Case 0
Case 1
LName = NameArr(1)
Case Else
If UseMiddle Then
MName = NameArr(1)
Next
LName = Trim(LName)
Else
Next
LName = Trim(LName)
End If
End Select
Else
StartsAt = -1
Do
Else
Exit Do
End If
Loop
End If
LName = Trim(Part1)
Do
Else
Exit Do
End If
Loop
' Get Title
' Adjust Part2
Else
FName = Part2
End If
End If
End If
With dic
.Item("Title") = Title
.Item("First") = FName
.Item("Middle") = MName
.Item("Last") = LName
.Item("Suffix") = Suffix
End With
Set dic = Nothing
End Function
Private Function GenerateLists(ListType As String)
Dim Titles As String
Dim Suffixes As String
' In creating the master title and suffix lists, keep in mind that the strings will be passed in as part of a
' RegExp pattern, and so typical syntax rules for the VBScript implementation of RegExp will apply for things
' such as optional characters and escaping reserved characters. For example:
' M\.? ?D
' matches M, then zero or one period, then zero or one space, then D. Use the pipe character to delimit your
' entries
' If the lists get too long to keep using line continuators, then simply break them up into separate expressions:
' Titles = 'Dr|Doctor|Mrs|Ms|Miss|Mr|Mister|Master|'
' Titles = Titles & "Reverend|Rev|Right Reverend|Right Rev|Most Reverend|
' Titles = Titles & "Most Rev|Honorable|Honourable"
' Populate master title list. This can be expanded according to your needs. There is no need to include a
' trailing period here, as the Pattern string built later on includes an optional period at the end. In cases
' where a title may be shortened, list the longer version first. For example, list Senator before Sen.
Titles = "Dr|Doctor|Mrs|Ms|Miss|Mr|Mister|Master|Reverend|Rev|Right Reverend|Right Rev|Most Reverend|" & _
"Most Rev|Honorable|Honourable|Hon|Monsignor|Msgr|Father|Fr|Bishop|Sister|Sr|Mother Superior|Mother|" & _
"Senator|Sen|President|Pres|Vice President|V\.? ?P|Secretary|Sec|General|Gen|Lieutenant General|Lt\.? ?Gen|" & _
"Major General|Maj\.? ?Gen|Brigadier General|Brig\.? ?Gen|Colonel|Col|Lieutenant Colonel|Lt\.? ?Col|Major|" & _
"Maj|Sir|Dame|Lord|Lady|Judge|Professor|Prof"
' Populate master suffix list. This can be expanded according to your needs. There is no need to include a
' where a title may be shortened, list the longer version first. For example, list Esquire before Esq. Also,
' list III before II, and II before I
Suffixes = "M\.? ?D|Ph\.? ?D|Esquire|Esq\.?|J\.? ?D|D\.? ?D|Jr|Sr|III|II|I|IV|X|IX|VIII|VII|VI|V|M\.? ?P|" & _
"M\.? ?S\.? ?W|C\.? P\.? ?A|P\.? M\.? ?P|L\.? ?P\.? ?N|R\.? ?N|A\.? ?S\.? ?E|U\.? ?S\.? ?N|" & _
"U\.? ?S\.? ?M\.? ?C|R\.? ?G\.? ?C\.? ?E|P\.? ?M\.? ?P|P\.? ?E|M\.? ?O\.? ?S|M\.? ?C\.? ?T\.? ?S|" & _
"M\.? ?C\.? ?T|M\.? ?C\.? ?S\.? ?E|M\.? ?C\.? ?S\.? ?D\.? ?|M\.? ?C\.? ?S\.? ?A|M\.? ?C\.? ?P\.? ?D|" & _
"M\.? ?C\.? ?M|M\.? ?C\.? ?L\.? ?T|M\.? ?C\.? ?I\.? ?T\.? ?P|M\.? ?C\.? ?D\.? ?S\.? ?T|" & _
"M\.? ?C\.? ?D\.? ?B\.? ?A|M\.? ?C\.? ?B\.? ?M\.? ?S\.? ?S|M\.? ?C\.? ?B\.? ?M\.? ?S\.? ?P|" & _
"M\.? ?C\.? ?A\.? ?S|M\.? ?C\.? ?A\.? ?D|M\.? ?C\.? ?A|I\.? ?T\.? ?I\.? ?L|C\.? ?R\.? ?P|C\.? ?N\.? ?E|" & _
"C\.? ?N\.? ?A|C\.? ?I\.? ?S\.? ?S\.? ?P|C\.? ?C\.? ?V\.? ?P|C\.? ?C\.? ?S\.? ?P|C\.? ?C\.? ?N\.? ?P|" & _
"C\.? ?C\.? ?I\.? ?E|C\.? ?A\.? ?P\.? ?M|S\.? ?J|O\.? ?F\.? ?M|C\.? ?N\.? ?D|M\.? ?B\.? ?A|M\.? ?S"
If ListType = "Titles" Then
GenerateLists = Titles
Else
GenerateLists = Suffixes
End If
End Function
First Middle Last
Anne Marie (*) Thomason Miller
John Ronald Reuel (*) Tolkien
John R.R. (*) Tolkien
John R. R. (*) Tolkien
Oscar de la Renta (*)
Jill St. John (*)
Comments (5)
Great article. Thanks! Voted "Yes" above.
What an outstanding article. I've struggled with these issues ever since the Radio Shack TRS-80 days. It's wonderful to have a reference that pulls it all together. This article has got to be one of the best, if not the best resource, on the subject. Got my Yes vote above.
Commented:I recently came across a situation where last names ending in "i" were being misinterpreted as a "I" (the first) suffix. A small tweak to the RegExp patterns appears to fix it.
The code below implements the fix, and in addition to that I have added the academic degrees MBA and MS to the suffix list.
Cheers, Patrick
Please note, I encountered the following bug in the code when running on my system (Access 2010):
FNLN$ = JUAN A BROOKS JR
debug.print GetNamePart(FNLN$, "Last") & GetNamePart(FNLN$, "Suffix") & "/" & GetNamePart(FNLN$, "First") & " " & GetNamePart(FNLN$, "Middle")
produces: BROOKS/JUAN A (without the JR)
I didn't trace the code, but on my system, calling the function with "Last" removes the suffix from FNLN$. I solved the problem by adding BYVAL to the declaration as follows:
ByVal NameStr As String
This removes the possibility of any inadvertent changes to NameStr.
Commented:Thank you for your comment. I tried but could not reproduce your result. I did notice one problem with your expression:
You have no separator between the surname and suffix in that expression.
Patrick
