Hi all,
I just bought a sweet set of 5.1 surround sound speakers; the Logitech X-530 5.1 kit. The speakers and sub all work fine and Realtek detects all the speakers but doesn't designate t...
I am looking to convert purchased audio books from amazon.com (file format m4b is what I have experienced so far) to mp3 files. So far, I have found one solution as long as I am on my PC wher...
I need a digital to analog converter box. My situation is this: I'm trying to record, mix and playback MP3 recordings using my Dell 690 Workstation COUPLED to a standard relatively high end st...
I'm using the plug-in vocoder for audacity for my robot vocals. However, the effect really lowers the volume. When I increase it to make it fit in with the rest of the project, the clipping ru...
I have an mp3 (actually an mp3 stream in a video clip) that has clipped audio all the way through. Is there a way to fix this (or a filter i can apply to take care of this)? The algorithm se...
how can we convert x-shockwave-flash file to mp3 using java ?
All I need to know is how to use the lame.exe to convert a u-law wav file to a mp3.
I can't upload the wav I have, but it's stats are:
BitRate: 64kbps
Audio Sample Size: 8bit
Channels: Mo...
I am looking for the information on which audio and video data types/streams are currently supported with .mov file format...?
