Experts Exchange is proud to recognize the top quarterly Experts of 2008. These Experts have risen to the top, so CONGRATULATIONS!
Time Tested Audio Editing Solutions: 1 - 25 of 31
I am working with DirectShow in VB.NET.   I have a number of the functions working, but now I am trying to capture Microphone input.   I have seen some examples, but they involve the use of IM...
We do Audio transcription We from time to time get files with echo, The echo is from making the recordings in large rooms. or uncarpeted floors. Need everyone suggestion to remove t...
Hi all, I just bought a sweet set of 5.1 surround sound speakers; the Logitech X-530 5.1 kit. The speakers and sub all work fine and Realtek detects all the speakers but doesn't designate t...
Hi Experts, I'm working on decoding G.729 received by RTP packets from Cisco Call Manager. I'm able to playback the sound, although the voice sounds almost alien or like a robot, with some cl...
Hey sibgig....I'm back again for more of your expert advise.  I did finish the web site you were helping me with.   www.betsyhickok.com I am working on a new flash website and was wondering...
I'm running Audacity v1.24 on my Windows XP machine.  I record calls with two people on them and the volume of the voices is not the same.  I have been using WavePad by NCH Swift Sound, http:/...
I want to extract the duration of the music in a mp3 file without having to play the entire file, just like Windows explorer does. I am developing with Delphi 6 and Windows XP Thanks for...
How do I play a *.au and *.raw format file in a Windows XP environment
I am looking to convert purchased audio books from amazon.com (file format m4b is what I have experienced so far) to mp3 files.  So far, I have found one solution as long as I am on my PC wher...
Hey there, is there any free and legal way to get mp4 files to play on windows media player. I've bought song on Itunes but it won't convert (because its license protected) and it won't play ...
I need a digital to analog converter box. My situation is this: I'm trying to record, mix and playback MP3 recordings using my Dell 690 Workstation COUPLED to a standard relatively high end st...
I'm using the plug-in vocoder for audacity for my robot vocals. However, the effect really lowers the volume. When I increase it to make it fit in with the rest of the project, the clipping ru...
I am trying to learn some songs on piano.  I'd like to download the tune from instructional videos I have as well as from dvd's into my hard drive.  I would then like to import the tune into a...
I have an mp3 (actually an mp3 stream in a video clip) that has clipped audio all the way through.  Is there a way to fix this (or a filter i can apply to take care of this)?  The algorithm se...
This is a question regarding C Programming: i am looking to generate audio using C Code. for this i am looking to generate a square wave function (does not have to be a square wave can be any ...
how can we convert x-shockwave-flash file to mp3 using java ?
How do I record audio in visual studio.net 2005 (visual basic).  Looking through the help there are about 5 different services that can be used to theoretically record sound (from a microphone...
I'm trying to import a 6.5 hour WMA (lectures) to Adobe Audition 2.5.  I need to edit the audio, so I usually pull it into Audition, edit, then export as an MP3.  This one, though, shows up as...
I've been called out to a job last week where the user complained that any music playback on the machine sounded "like they were on helium".  Sure enough, each time I play an MP3 or just tune ...
Is there any software that can convert audio from a wav file into numbers? any idea how this could be done.
i have download a movie from internet and when i watch the movie the guy in the movie is talking and the audio is like one sec off. so i want to know what i should do becuase audio realy doe...
I would like to establish a connection to an Internet radio station transmitting in Windows Media format over RTSP.  I do not want to play the received sound, but convet it to MP3 and save it ...
How do you create a way for a user on a Flash web site, to click on a link and play an MP3 or aiff file in Flash 8?
Hello, I have been asked to set up 4 self powered speakers in surround sound for a temporary outdoor theater. The problem is that the speakers only have XLR and 1/4 inch inputs while the re...
This may sound like a stupid question but I would like to know if I can extract the audio from a DVD such as a comedy DVD and save it as an mp3.  I use XP Pro and I have Nero 7.  Could Nero do...
