I use very frequently the capability of creating a unified diff between different branches. To my dismay, this feature has apparently been removed in the 1.5 release, which I just discovered a...
When using xcacls.vbs on the local machine, it is possible to change ACLs with local users, however, it can't find any domain account. The computer is joined to the domain and when using cacl...
I have lost access to my start menu. I also cannot change my settings in GPeditor. Extended tab doesn't work at all and items under standard tab aren't editable.
thanks
Doug
I have many PCs running in a manufacturing plant. Newer PCs come with an annoying default setting of 15 minutes before stand by. The local machine account does not have permission to change t...
I want to keep track of the daily changes I make to a script by using CVS. I'm running into a problem updating the CVS records.
I currently have a script that checks out the rep from the CV...
Hello experts, There is an application (c# @ vs2005 SP1) that needs to be deployed in a very controlled way.
ClickOnce was selected to do this task.
This application works over a databas...
I'm trying to analyze our CVS repository to find all new files created since 3/22/2008. We're running CVSNT, so using the Windows search function doesn't work, because Windows doesn't properl...
hello experts
i want to change my login name
how it is possible ?
In Photopaint the default "Save to type:" was always .jpg. Then I made an animated .gif file and save it as a .gif. Now everything defaults to .gif and it's getting tedious trying to remember...
Hi
I have the PC version of Adobe Design Premium CS3 and would like to move over to Apple. This will be a permanent move and so would Adobe allow a licence & software swap and if so what is...
In order to fix our WOL issue, I need to change the "Allow this device to bring the computer out of standby" setting under the power management tab on the NIC card. We have 40+ workstations a...
How can I change the size of the clipboard to avoid the message "large amount of information on the clipboard"
