Can someone try to help draw an Entity Relationship diagram for a database... I neglected that part of my study and feel hopeless.. Any help will be much appreciated.. The file attached states...
I want to convert the following NSC colors to Pantone. The colors are:
S 0502-Y
S 1030-Y10R
S 8000-N
S 5500-N
S 1500-N
S 1005-Y10R
S 1502-Y
S 4030-R90B
S 2005-Y10R
S 3005-Y50R
S 050...
Where can I find a good example on how to completely implement the MVC pattern in Windows Forms. I found many tutorials and code examples on various sites (e.g. CodeProject, .NetHeaven) but ma...
What is system development methodology as well as the advantages and disadvantages
I've done a use case diagram (pdf file) about how the loan book work in my company. I need now to do a class diagram of it but I don't how to do it.
Could you help me?
This may sound like an odd question. I a freelance webdesigner who is just getting into business card design because clients wanted them. I was able to hook up with a company who will p...
Hi pals,
I wish to build a 3-tier software and I am confused about which designing approach to use. I intend to class diagrams, use-case diagrams and activity diagrams but I am frustrated...
Hi, i was reading a book on SDLC...when i saw this in the book but not quite understand what is meant by stub and drivers in integration context.
Integration can be undertaken either top-do...
What are the scenarios when we should only
Implement Interfaces, when only abstract classes and when both can be used.
multiple inheritance is not allowed i know that.
Experts,
I have a directory with many subdirectories, all of which contain files with a .dta extension. I'd like to rename the files in the parent directory and all its children to another...
I'm in a bit of a time crunch with this one and I am NO DBA. Three scenerios. Points go to whoever can answer all three with an ERD.
A company wants to maintain data on field operations of ...
Hi All,
I would like to know if you could outline your Software design methodology or approach. I am embarking on a .NET project and would like to know what the baseline approaches are. Is ...
How we can create a object model for a given database schema.
What is the basic purpose and functionality of object model.
Pls explain it clearly by some fogures.
Pls don't provide me the s...
Can anyone list out strengths and weaknesses of Booch method?
object oriented analysis and design.
I'm trying to figure out the best way to construct database tables to support what are, programmatically speaking, derived classes.
My base class will be "Request"
"OriginalRequest" & "...
Hello all,
Just looking for some design guidance on how to best setup the switching environment for an iSCSI SAN. I will have two VMware ESX servers, 1 physical database server, 1 physical ...
I am looking at a folder structure of a javascript software. There is a folder structure:
com, org, net, generated. Can someone explain this folder structure that seem to be used generally in...
I am moving from ASP to ASP.NET. In the past, I set up a zillion pages using ASP, but coding without using any wizards or controls (FrontPage was my tool). I would simply use ASP (via VB) to...
have you got some experience with model driven development in C#? I'm especially interested for tools enabling transparent transition between model and code and vice versa.
thanks
Henestly, I only know two rational software design approaches so far, UML and Booch and i dont think that's all. Especailly, UML, Every of my SW projects need to use UML appoaches to communica...
Now i've been thrown into the water of planning, organizing and co-producing a major web project.
Project rough: internet job tendering platform, basic structure, functions, data flow is kno...
Hi, I am working with a group of software developers and consultants that are using the Agile process for a project that I am providing domain expertise for. The user testing conducted at the...
I am a lone developer.
I want to use a design methodology that forces me to use good practice.
What would you recommend?
I am a C#, ASP.Net developer.
Particularly helpful would be to be p...
I'm about to launch a new portfolio website for a very specific industry area and I'd like to show some my best work for an old client. Unfortunatly we didnt finish the realtionship on the bes...
Hello there,
I am designing an A4 double sided single folded leaflet for a takeaway. I am designing using Adobe Photoshop CS2. The screen resolution I am designing in is 354 dpi CMYK colour...
