In Active Directory on a Windows 2003 server environment in native mode, how can I tell the last time&date a user Logged on ? Trying to identify idle/dead accounts
I've checked the other posts here and haven't quite found what i'm looking for interms of a solution. One of our users has an archive folder that has gotten quite large, and his local HD is f...
We have a windows 2003 active directory environment and our compliance officer has asked us to disable the games that come with xp..... I would really like to do this via group policy.
Any...
I am trying to figure out how to set up a scheduled defrag task with Group Policy.
I am very new to this, and I am having a great deal of difficulty determining the proper way to do this. I h...
We are in the process of upgrading our entire network infrastructure. One major component is Active Directory, which we don't have yet and are working on a design. My problem is that we will b...
I need a list of command bar id's for outlook 2003. I am trying to diable the format catagory and also the format message dropdown when a user is constructing an email. We are moving to a plai...
I know this is probably real common and easy... however my search over this site and the internet suggests otherwise. I work in a K-12 environment and we are an 2003 AD environment as well. ...
The environment where I work locks most PC's so the user is not able to install or remove software themselves. During a separate process a folder is created with several junk files that need t...
Could someone tell me the best way of finding out which OU a user or computer is in? We've got lots of OU's and finding where objects belong can be a bit of a pain.
In the project i have to work, i have 3 large applications, 10 medium sized applications and 30 small applications.
Applications written in Java, .NET etc. are to be rewritten into Oracle ...
Assume that your project team starts falling behind schedule. Please could you describe strategies for making up lost time and avoiding schedule slips in the future?
Is there a command I can use to export AD user accounts by OU to a spreadsheet or CSV?
Im setting up 2 servers which mirror each other with a cron running "unison" (similar to rsync).
Currently Im mirroring the /var/www folder for apache and the apache vhosts folder.
My qu...
The automated move data files within sbs 2008 console works for all files EXCEPT sharepoint - which is 25gb in size and I NEED to move.
Apparently it is possible to do it manually.
cann...
We are running a Windows 2003 server environment and our agents have windows xp on their stations with roaming profiles. The Managers want to be able to check and see when an agent logged int...
I need to make changes to users registry settings on a terminal server. How do I look up the user's SID?
We have a broad range of users from developers and testers to Desktop Support, etc. Apart from security groups which allow domain level access for help desk and users, we have the need for loc...
Hello!
We have a problem with Roaming profiles and Outlook that I'm hoping someone can help with.
Basically we have 3 Citrix Presetnation Servers that have Outlook 2003 installed and running...
I am trying to map some network drives using a GPO on an SBS2008 server. I have linked the GPO within the SBSUsers OU under which all our users reside. I have enforced it and assigned is permi...
Hello all.
Let me start off by saying that I'm not a Linux expert. But I've been tasked with making an image for a cyber defense competition and one of the requirements is to create a hidden...
Hello, I got the classical problem that new users/groups does not show up in the GAL and Outlook Addressbook and I have performed the following troubleshooting steps:
1. Triggered Download ...
Looking for way to add password-protection to restrict opening Task Manager and ZoneAlarm (i.e. block getting around parental controls). My young son saw me use Task Manager, so now he uses i...
We have successfully configured our UNIX environment (AIX 5.3 and Solaris 10) to be Authenticated with Kerberos and LDAP authorization using Windows 2003 R2 Active Directory as a Kerber...
hi I suspect a few of my users profile on TS is corrupted and so I would like to correct this problem. Do you think deleting the ntuser.dat would to the job or I should rather rename the whole...
Hello and Thank You,
My company is moving from a peer- to - peer, workgroup environment to a Domain with SBS 2003 R2 at its core.
A question I have is about Clients at the application le...
