06.06.2007 at 01:43PM PDT, ID: 22617493
Excel VBA Code to Change the Format of a Subset of Points in a Single Series on a Line Graph
Asked by Rex85 in Program Quality Control, Microsoft Excel Spreadsheet Software
Tags: , , ,
I am writing an Excel 2003 VBA module that updates a statistical control chart. I am running XP Pro on an IBM T42 ThinkPad with 1 MB of RAM.
I want to subject each newly plotted point (It's basically a line graph if you are not familiar with control charts) to a series of statistical tests and then change the color of that plotted point (and only that plotted point!) from Black to Red if the point fails any of the tests.
I can't find a way to do this, and some forums have even said it's not possible to have a different format for only one point (or a subset of points) in a series. I would appreciate any help. Thank you.Start Free Trial
[+][-]06.06.2007 at 02:10PM PDT, ID: 19228593
[+][-]06.06.2007 at 02:11PM PDT, ID: 19228599
[+][-]06.06.2007 at 04:27PM PDT, ID: 19229337
Zones: Program Quality Control, Microsoft Excel Spreadsheet Software
Tags: vba, excel, format, change
Solution Provided By: rorya
20080716-EE-VQP-32
