is UNION ALL allowed in MQTs on V5R3?
Can an MQT select from another MQT in R5V3?
Look at lines 38 & 39
With just line 38 ... it compiles
With just line 39 ... it compiles
But with both 38 & 39
... I get error line 93 - "Select/omit not valid for file IJCUTL1L1 when D...
I have an AS400 file. This file has an external descripton on it. I created a cpytoimpf to send it to a ahared drive that the PC user can acess to get the CSV file. My only problem is that ...
A user delete all the qjoblog and we need to recover them - any ides?
No they were not backed up
Per DOCs ....
I quote
"You should avoid using the REFRESH TABLE statement to update user-maintained materialize query tables."
and again
"Use insert, update, delete, or lo...
I have one printer file (RLU) in which i want to print multiple colours based on the values / description.
is it possible.
when i am trying to assign the keyword "COLOR" system is giving ...
