Time Tested AS400 Programming Solutions: 126 - 150 of 582
I try to transfer an excel file to AS400 vis client access. In the excel file  I have the numeric data in a character column. I parameter the access to conver the numeric to character and i...
I am working on an AS/400 (iSeries) server with OS/400 V4R5 I need to send an HTTP Request to another server (Microsoft BizTalk; outside of my control) to exchange data from the iSeries ser...
Dear I have a schedule job(RTGS_SCH)  on AS400 that it is call PGM program (QGPL/RTGS_IOQRY), I can't use WRKMBRPDM and STRSEU command because the machine can't installed a development too...
I need to view the SQL of a table/view (S5833.NFRANK.ORDERQTY) I have used the QSYS2.SYSTABLES and QSYS2.VIEWS but it doesn't show the SQL.  This is a generated table or view that someone m...
I would be grateful of any assistance with this.  I have inheritied some batch files from a previous developper and I am new to AS400 development. The batch files contain the following line...
I am a beginner to rpgle. I would like to create a program that connects to a db2 database. Example: field name:      Name:                         Date:                         Memo: ...
Hello I need the documentation on the cwbx.dll. I have searched the IBM site to no avail. Can anyone help?? I am creating a DLL (in VB6) to call a programme on the AS/400. I can see all ...
Hello all. I need write a program that  process  spooled files that are in a specific OutQ. All I have is the OutQ name. I need to get all the information about the spooled files(like job,j...
I'm new to the AS/400.  I work at a help desk that now supports some As/400 users.  Can you tell me the first steps I should take when trying to troubleshoot a printing problem in As/400.  Al...
I'm studying about AS/400 System. Comparing to Windows, it's hard to find some information about AS/400 on Internet. Although I've some documents from IBM site, it's also difficult to unders...
how can we compare the version v5r4 vs v6r1? is the version v6r1 is better than v5r4? what is the benefit and drawback of v6r1 over v5r4?
So, I'm a system administrator with years of linux and windows experience. I've got one machine here that is a thorn in my side though. His name is AS400. I'm coming to realize that I kn...
Hello, I need a way to set an outq to save all spool files.  Currently we can setup the spool file itself to save but we need a way to do this from the outq level. Thanks, Cleavis
Greetings, We have an iSeries model 550 running V5R3. We run JD Edwards software along with TL Ashford label software. My question is this... I have a program that runs an interactive ...
Hi I have AS400 printer files with overlays applied to them using OVRPRTF. I want to contvert them to a PDF format on the IFS so they can be loaded into a archive system. We have a utility t...
The Labels can not be printed out on Zebra Printer. (The status of Label spool file is HLD after directed the spool file to zebra printer.) The name of Zebra printed on whhich it need to pri...
Can any one please send me the Sample PGM which will access the data from the IFS file & put that to the Database file in AS400? TIA-MW
I can't work out how to do an unattended (silent) uninstall of iSeries Client Access 5.3. I can't call it using msiexec /uninstall, can't run setup and write to an iss file and the program I f...
Hi, We have an application which is based on the OS/400 platform. The GUI code is in J2EE. We are using the DB2400 database that comes along with the OS. To meet industry compliance, we ...
How can I type the PCL "escape" command in AS400 prompt? In Dos Edit I simply use the sequence CTRL+P+ESC, but in AS400 I only know how to do it by creating a WSCST and assingning a unused ch...
Hi,    This might be newbi since we are really new to as400. We have an AS400 server. We are installing some PTF( 2CDs) files on the server. After the 1st one, I have a message saying 'waitin...
I know this seems pretty stupid, but I can't compile any C programs on the as400.  As an example, I've listed the classic "Hello World" program: Here's the source (many variants tried): ...
I am using Kaplan's AS/400 App dev using COBOL/400. From the examples, I created a display file called HELLOWORLD using SDA. SDA created the following files YOURLIB/QDDSSRC/(HELLOWORL...
Hi, I would like to know if there is a way of printing a PDF document that is stored in the IFS (QDLS or /dev etc.) to an OUTQ on the AS/400 ? Many Thanks Rob
I will change a new ip address on remote printer Please teach me how to do it
