Why does MS Project parent task double the number of hours in the child tasks?
For example, my parent has 44 hours but the child tasks only add up to 22.
I want to show start, duration, finish date columns where the duration automatically calculates the difference between them.
HOWEVER,
I do NOT want all rows to have dates. I'd like to be ...
I have a "Support" task in one of my forecasting plans I'm using to show team member allocation across various projects over the next 36 months. When trying to edit the task, I get the follow...
Ok we are using MS Project 2007. We are publishing to our Sharepoint site. Everything is publishing fine except for the calendar. We can get all the documents and see them on the server, but t...
We are considering using project to keep tabs on the things we need to accomplish daily, weekly etc.
What I need to find out is can the items we put in Project be linked some way with Outlo...
