How can I conver MS Project 2007 documents to MS Project 2003 without using 2007? Is there a stand-alone utility out there that I can use?
I have a user that is going through MS Project 20...
I'm using MS-Project for a school project. Entering the activities and creating a linked Gantt chart was easy.
In addition to the Gantt chart, we also need to include a "PERT diagram". ...
It's my understanding that after you're finished assigning estimated Work hours on your tasks, you can make a Baseline before people actually start working on your project.
Then late...
Is there any place I can download a trial version of MS Project? The Microsoft page has an option for download 2003 standard, but the download button asks for details to order a CD!
When I try to install Microsoft Office Project 2003, I receive the following error message:
How do I export the Gantt chart from Project to Excel? Using 2002 version
When I right-click a task and open a hyperlink, I alwasy encounter the annoying warning:
Some files can contain viruses or otherwise be harmful to your comput.r
It is important to be certai...
Is there any way to transfer event dates etc from Microsoft Project to a Microsoft Outlook calendar without requiring Project server?
Thanks in advance,
Mark
Is there any freeware available for microsoft project equivalent , which can do mpp file view as well as edit to make the changes.
How can I make a min,max and close button as invisible of a form in C# on run time? When I changed the form property it occurs on design time only. But in run time it is visible? Please give m...
When trying to access Project Web Access (PWA) site https:, receiving Access Denied message. This also occurs when trying to login with any domain or local admin account. Receiving Applicati...
I have got Project 2007 and Outlook 2007
I need to import my tasks in to Outlook,
I have looked for a tool to do this but they are either trials or you have to buy them
Is it possible to c...
Microsoft Project can create an MS Access database or a MS Project database when you save the file. Has anyone created a SQL Server database with MS Project? Did it bring over the data model...
The Microsoft Access database engine stopped the process because you and another user are attempting to change the same data at the same time. (Error 3197)
I have a sharepoint site setup for my clients using Sharepoint Services 3.0.
My Development team has sent me a mpp file, but I do not have Microsoft Project nor does the client. Si I need ...
I need to help with data analysis to extract data from the timesheet component of Project Server 2007.
I have built the cube successfully and I'm pretty confident all the data I'm trying to r...
Hi, I need to convert a file with extension XER from Primavera Software to Project Professional 2007, Do you know how I can do that?
hello,
I urgently need to deploy an hotfix on 90 computers that have MS Office Project Professional 2007 SP1
i tried to import this using MS WSUS 3.0 but at this hotfix is not listed in the ...
We have a project that was supplied to us by a vendor. There are some hardcoded dates in it that are wrong (this is just a template); what we'd really like is for all of the tasks (well, wher...
I have Office 2003 installed and Project 2007 on a WINXP pro SP2 Machine. Every time I open outlook 2003 a 'Configuring project 2007' dialog box comes up. It takes about 5 mins to co...
I am getting all the attached errors in my project server. Windows SharePoint is working fine, but PWA is showing error "An unexpected error has occurred. " All sharepoint operations are seems...
I found a Compatibility Patch for Office 2003 to convert 2007 versions of Word, Excel and Powerpoint files and open them/etc.
Does anyone know if somethign like this exists for MS Project?
I want to be able to expand all the summary tasks in one shot!
At the moment I have to labouriously click on each little plus sign... :(
for auditing purpouses I urgently need to check what is the ip lease time history of a dhcp address.
the aim is know when exactly that dhcp address is being used on a computer, the da...
Duration weeks I enter for a set of sub-tasks do not roll-up to the HEADER..
Any input. Thanks
