What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Time Tested MS Project Solutions: 26 - 50 of 284
hello there we have files in P3 format for Primavera . but we want to open them thru MS project . is there any soultion to convert the P3 files to MPP files or open it thru MS projects ? ...
I am getting all the attached errors in my project server. Windows SharePoint is working fine, but PWA is showing error "An unexpected error has occurred. " All sharepoint operations are seems...
I've set up a 2-server farm for MOSS 2007 and Project Server 2007.  One machine runs MOSS and Project (both SP1).  The second machine runs SQL 2005 SP2. I hope that someone can help me figu...
Hi can anyone tell me how to add holiday dates to resources in microsoft project please.
Hello, a user has Project 2000 and needs to convert a Project file into a PDF..what is the best way to do this? Also, what file extension does project use? Thanks
Hello, Duration weeks I enter for a set of sub-tasks do not roll-up to the HEADER.. Any input.  Thanks
Is there a way to link an MS Project file with an Excel file? All I would like to do is take the date from a cell MS project file and output the date into and Excel file cell. Can I do this wi...
Does anyone know where I could find a MS Project Database Schema for developing reports. I want to generate a report which shows user hours by day entered for a specific project in project ser...
Hello, We use Project 2003/2007 in our enviroment and we would like to allow users that do not have project installed view project files.  If possible we would like to avoid exporting to an...
My project managment office is wanting to use Reporting Services with Project Server 2007. How do I configure SQL reporting Services to work with Project Server.
Is there a way I could have a Microsoft Project info about a Project Schedule show up in Calendar format like how it shows up in Microsoft Outlook in the Month view? I want the user to see ...
I want to be able to generate any report in Project 2003, and instead of printing it, I want to take the report's results and export it into Excel so it can be formatted more than Project will...
I had added a couple of unwanted "resource names" in my MS-Project project. Any ideas how I remove them? They are unused. Many thanks, Ed Hasted
Hello, How do I access Project Web Access. I have installed Project Server 2003 onto my server and I have Project 2003 Pro onto my computer but I am unclear how to access Project Web Access...
I have performed a basic installation of MS Project Server 2007 on a W2k3 R2 Standard box. The install automatically configures SQL Express 2005, IIS and Sharepoint for you. The issue  is I cr...
My project spans from now until Sept '09.   I want to print the project so the gantt chart only displays from now until the end of fiscal year (Mar 31, 09).   I also want to restrict how m...
I am trying to install Project Server 2007 on my standalone MOSS 2007 installation.  I am at the point of running Sharepoint Configuration Wizard.  It is now failing on step 6, starting the Pr...
Hello, We have set up MS Project Enterprise on a SHarepoint server.  Everything is working fine.  The only issue we have is that the Outlook integration imports the tasks to the calendar....
Hello....I would like to manually change the labels in a Gantt chart that I have created. For instance, I may have the same shape that has multiple colors throughout the chart.  I would like t...
I am a new user so my experience is limited.  Here is the problem I am having.  I have projects tasks set up from 1/1/2008 to 12/31/2008.  When I print preview a Gantt chart, it only shows me ...
For some time I haven't been able to download any ms updates.  i carefully choose some once in a while that i think are good.  It goes through all the motions, then states that the following w...
I am trying to forecast my project costs from now to 1 year out in terms of $ spent on personnel and resources. Best if I can show actual vs expected. If possible, How do I produce a cu...
How do you get Project to recognize weekends as you do your planning??
Here is my sample project: Task    Duration    Resources T1       2h             R1;R2 T2       2.67h        R1;R2;R3 T3       4h             R1;R2 T4       3h             R1;R3 T5      ...
Hello: In Microsoft Project, 2003, I'd like to conditionally set the color of the task text, based on the value of the task.  I found (and used) a variation of the VB code that dbase118 post...
