Hi Experts:
I am new to Project server 2007 and i am working to create a text file from the Project server Database with some fields in it. The fields contain Different Projects with differen...
Createing a Project in MS Project 2003. I want to have RED on first 30% of the horizontal bar , Black to next 50% and Green in last 20%. This is pretty standard for all the horizontal bar, I m...
Project Server 2007 on MOSS 2007 Server
Project Pro 2007, Outlook 2007
Users need to open projects from the Project server from Project Pro 2007. Upon selecting the server profile on the P...
I have multiple MPP files that I can no longer perform a "Save As' (into Excel, csv, etc) on. I am now getting an "Operation failed" message box. There never used to be a problem, but now ther...
I have to rollout 300 new PCs and I am looking for some Project 2003 templates.. Can anyone help?
How would I host project server 2007 in a virtual environment? Seems like a simple question but I don't know enough about virtual environment. This is my plan:
I want to take all 200 server...
Scenario: I have deployed Office Enterprise Edition 2007 over LAN with SMS 2003. First I have customized Office with OCT and then deploy it with SMS 2003. Now I want to deploy MS Project Pro 2...
I have a user that has been using Project 2003 for several years. He last used one particular file in November, and now when he tries to open it he gets this error message:
Project cannot op...
I am new to Project Server 2003 and Project 2003 Professional. My customer has been using Project 2003 Standard on a single client computer for their Home Building Business and has many .mpp f...
Hi. This is my first time with project and am facing few problems. I would like to know how do we display the dates on the Gnatt Chart. I'm using a tracking Gnatt chart. Its like I'm creating ...
I know in MS Project 2003 one could save a Project file as an Access database; however, it seems that Microsoft removed this option in Project 2007. I had some one on my Project team create a...
All
We are useing MS Project Central SR1
When trying to create a new Task I recieve the following error.
"Microsoft Cursor Engine error '80040e21'
Multiple-step operation generate...
I have one server which now have SQL 2005 standard installed on it as well as SharedPoint Server 2003 and I am trying to install MS Project Server 2003... The shared point is working with the ...
I have a project with a set of tasks that are repeated over and over again through out the life of the project. To be exact, this is a farming project where I am dealing with a few hectares of...
Hello MSProject Gurus,
I am being forced to track actuals hours worked against my project plan estimated hours. I have the plan set up and it ties to the total number of hours for the entire...
We are receiving the following error when attempting to log into the PWA from the server on which Project Server is installed. We have read the other posts which do not help our situation. W...
I have a very simple project for learning MS project.
I assign a task a duration of 10 days contrained to start on August 1st.
I use tools > change working time > and and assign John Doe ...
Specs: Windows server 2003 SP1 with Project server 2003 SP2a, Share Point 2.0 SP2, SQL 2000 SP3
Installed Project server using the Project 2003 Bible installation instructions.
On the home...
I am very new to project managment and to MS project (we have MS project 2007). I have been reading this forum for a few hours and I have gotten some really good information, so thanks alread...
We are in the process of installing Microsoft Project Server 2007. We need to produce reports using the data which will get recorded using various sharepoint features. eg timesheet, project in...
Hello
My server has installed
Windows 2003 Server English
.net Frame Work 2.0
net frame work 3.0
IIS services
SQL Server 2005
ASPnet from Ms-dos
Share point Service s 3.0
Project Se...
I have the below formula, and I would like it to round to the nearest whole number. Formatting won't work either, as I want to use the number a another formula too. This is in a custom numbe...
Presently we set up MS Project 2007 to list predecessors in column Text1, list predecessor name in column Text2, and in column Text10 will show predecessor ID and predecessor name separated by...
Everytime I open Microsoft Project 2000 I receive this error:
"Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\Microsoft Office\Office\WINPROJ.EXE
This ...
Hi, I'm new to Microsoft Project and am wondering how to resolve the overallocation issue. Suppose that a resource named A has to do three tasks in parallel over 5 days, so the timeline looks ...
