I'm getting this error when I add an Issue on the Project's PWA site. I'll submit the addition and that alert prompt will come up and I hit OK, but somehow it adds the issue to the db. I'm n...
I've been assigned to be the Project Mgr. for our 1st use of MS Project. My boss and I attended a 2 day seminar on Project and both of us came away still a bit confused. The project I have t...
We are a very small company (9 people total) and in need of project management software and we are trying to figure out how to get the most value for our limited monies.
I am virtually comp...
Previously, I installed Project Server 2007 with a licensed version, using one server for all Project services, and another machine for SQL 2005 databases. It worked pretty well, except I cou...
I hae a database that is linked to an inventory database. I would like to have when a person enters in a serial number of lets say a monitor in a box below it pulls the type of monitor from th...
I hide some columns before taking a snapshot of my schedule to send to a client but now I can not figure out how to unhide them. Help I am a novice at this software.
Thanks Apex
Hi Can i create a project that shows the businesses set annual holidays, but also allows me to add team members and update a calendar with the member of staff's holiday requests throughout the...
Hi!
Although I did refer to a previous thread in this forum regarding MS project installation issue where it reports back that another instance of Project 2003 is running, still not helpful.....
We have a new warehouse and need to implement BarCode, Shelf Handling, Item tracking on the shelf, date expiry and FIFO.
I need to create a proposed WBS or project plan, can I get any outli...
Good Afternoon,
I am testing our ability to archive projects and have created a test project for this use. Is there a way I can backup just a single project rather than all the projects in ...
Is there a solution out there for MS Project Server 07 for time phased earned value reporting.
In Project Server 03 there was an extender for earned value. Is there no such thing in 07?
I have a list of jobs in an access database with start and completion dates - I am looking to create a Microsoft Project to display the list of jobs and show the gantt chart part.
Appreciat...
I have a clean install Windows 2003 SP2 server, member of a domain.
I installed Sharepoint that connects to another server running SQL.
Sharepoint works, I can add users, access it from wher...
I am in PWA and click on Admin, go to Manage Views, and then try to select the top view under Portfolio Analyzer views and I get the error message: Unable to access the Microsoft Office Projec...
Can I install Project 2007 on the same PC as 2003 and access both individually?
I currently have MS Project 2003 and that is a standard for some of my clients. I need to install 2007 thoug...
I try to uninstall Project Server 2007 from Windows Server 2003 but when i try from Add/remove program it just flickers and does not remove it. How can i completely remove project server 2007 ...
When using Microsoft Project 2007 get error message "List of common English (United States) AutoCorrections is not available. Microsoft Office Project cannot install the necessary files due to...
Hi there,
im trying to parse a project XML file into a project database, but I can't seem to work out how to convert the time definition of PT0H0M0S into a Float value....
has anyone had...
When accessing the Project Server 2003 web site the server itself, I can use the portfolio analyser (Analysis services) without problem.
When I try to do the same thing from a client, when I...
When I try provisioning Project Server 2007 which is integrated with MOSS 2007 . It gives me Failed see Event log which is Event ID: 6971, 6993, 7071 etc. It first says Waiting for resources t...
? I want to be able to define a task that runs for a period of three months executed one hour per week only. The scenario is that I have a service oriented company that wants to streamline t...
Is it possible to generate a task list report for just one resource or page break for each resource?
I'd like to occasionally distribute hardcopy tasks and updates to each team member.
T...
I am looking to setup a Microsoft Project 2007 server environment for 10 users. What components do I need to do this?
Obviously MS Project Server, but is this all? Does a CAL give everyon...
I recently upgraded to Office 2007 and Project 2007 from Office 2003 version. Now when i try merging an Excel 2007 format sheet with the project template (.mpp) i get an error message as below...
I am trying to create a package for ms Project 2007. I am following the procedure from here but hitting a hurdle of it not correctly reading the .msp file i think. This link is what I am usin...
