Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested MS Project Solutions: 176 - 200 of 284
I have a Windows 2003 Server running SharePoint Services and IIS 6.0 along with Microsoft Project Server 2003. I have been unable to set up the email notification and reminders on the MS PRoje...
Anyone knows what FLC project is?
I got access to Project server 2003 from project prof. 2003. after opening a project I publish it with collaborate->publish->all information. (no error messges). When I go to collaborate->pro...
Hi, I have a Microsoft project file on my PC that I am using to display a critical path of 60 projects.   These projects have interdependecies that I have identified on my file that I lo...
Everytime I open Project, I get the above error. Error Signature: AppName: winproj.exe, AppVer: 11.1.2004.1707, AppStamp: 40ebc70a, ModName: kernel32.dll, ModVer: 5.0.2195.7006, Modstamp: 41dd...
Hi! Although I did refer to a previous thread in this forum regarding MS project installation issue where it reports back that another instance of Project 2003 is running, still not helpful.....
When I try to open a project (in MSP Pro) from PWA, I get the error message: "Cannot Connect.  Project was unable to establish a connection with the selected project server."  I can get in...
I'm building a network Diagram in MS Project. I want to draw in additional shapes boxes and lines.  eg. use the drawing toolbar.  The toolbar is greyed out.  How can I accomplish what I wan...
I've been assigned to be the Project Mgr. for our 1st use of MS Project.  My boss and I attended a 2 day seminar on Project and both of us came away still a bit confused.  The project I have t...
Last month we changed our database environment from SQL 2000 tot SQL 2005. Today we wanted to get the OLAP cubes up and running again in the new environment. After a lot of work and following ...
Hi Experts, I need to give some users access to one MS Project 2003 file, that they may edit, I need to have it automatically highlight the changes done, or anything that indicates these chan...
Hi, I'm using MS Project Standard 2003 and I have an issue with the units changing.   Essentially, I think a lot of the problem may be caused by a bug in Project where if you edit an amo...
We have done a migration from Project Server 2003 to Project Server 2007, following all the recommended steps. The migration completes successfully. The problem we are facing, is when we try ...
My Project Task in PWA are not displaying in the Project Workspace (Sharepoint) Task List. Here are the steps we have done for configuration 1. Setup Shared Service Administration for Proj...
I recently obtained Project Server 2007 and I am trying to install it. I am getting "They key is incorrect..."  However, I am typing it correctly (tried MANY times).  So, now I wonder if what ...
I am creating an application which queries windows using pdm to find out specifics for memory usage, processes, etc. and then has flags for when criteria are met.  It also monitors what window...
We are trying to perform an UpdateStatus PSI (Project Server 2007) call in our home grown application and often get a message regarding with "AssignmentUidInvalid" even though we are retrievin...
Error Type: Microsoft VBScript compilation (0x800A0411) Name redefined /sarTeacher/connection/connector.asp, line 2, column 6 const TBL_ULOGIN = "tbl_UserCT08" -----^
We had a corrupted project in Project Server 2007. Had weird behavior and just refused to be checked in. Fixed it by saving it to an MPP, deleting the Enterprise object, then reloading from...
I am in technet subscribers download area and wants to download the project server 2007 i have following options which one is the correct project server 2007 that i need for colaborative setup...
I have a Windows 2003 application server that has MS Project Server 2003 installed using MSDE2000 instead of SQL.  I had some problems with the install but after paying for Microsoft's help, g...
Hi, I have a problem with Project Server 2007 not synching with active directory. The error descried in the event log is: Standard Information:PSI Entry Point: Project User: DOMAIN\jam...
I was reading this thread and I am wondering how you get the custom Fields to display in MS Project 2003? I like the idea of having red, amber, and green indicators.
Good Afternoon, I am testing our ability to archive projects and have created a test project for this use. Is there a way I can backup just a single project rather than all the projects in ...
When I try to run the web page that contains a custom web user control '.ascx.' file I receive the following error: The type of page you have requested is not served because it has been e...
