I have a project schedule, my project with schedule time start in Nov, 2009. But the Gantt Chart start showing from Jun, 2009. How can I change the Gantt Chart so it start showing in Nov, 2009
We are experiencing an interesting issue where by when we decrease a resource allocation on a task to 40% or below, a subsequent tasks end date is pushed out. Attached is a before and after sh...
When I try to run the web page that contains a custom web
user control '.ascx.' file I receive the following error:
The type of page you have requested is not served because
it has been e...
I have installed Windows Sharepoint Services 3.0 and let my users load data into it. I am running a standalone configuration and using windows internal database. I have recently purchased Proj...
Does MS Project 2003 support or have the equivelant of a 'soft' dependency?
A soft dependency will not prevent the task from being performed if the dependent task deadline it is not met. The ...
I recently uninstalled Project 2003 from a PC running Windows XP SP2. The uninstallation completed successfully and everything appeared to be fine until the user went to open a file in Visual...
Hi all, I am in desperate need of knowing how to extend the olap cube in project server 2007. I have been looking online however, I can only find information on extending the cube for project ...
I have a project which is a fixed price contract. The project is worth $200,000. I have 3 CLINs represented as summary tasks and used as a baseline. As the project continues I would be enter...
How can I display the percentage next to a resource in the Gantt Chart view of Microsoft Project?
I have attached a word doc containing the snapshot of what I wish to accomplish (circles are ...
Whenever I try to open a project file using Project Pro 2007 the only thing that appears is the menu bar. I have comfirmed the file opens fine in Project Pro 2003.
Any suggestions as to h...
Hello - I'm looking for a way to set the default bar format in MS Project. In order to display the "start" to the left of the bar and the "name" to the right of the bar, I have to select each ...
Much of the Project management software that is out today has some variation of this format that really draws in your attention to only what you need to see at that moment. I dont see this ...
Hi All,
I am hoping that you maybe able to assist me. I am having a problem
installing MS Project Server with SQL 2005.
I have installed SQL Server 2005 Enterprise Edition and Widows S...
we are planning to install the MS Project server 2007 in our environment.
Can someone tell me briefly the difference between MS Project Professional and
MS Project Web Access.
1) Can we...
When trying to install Project server 2003, i receive this error, see attached. I have SQL 2005 installed and I'm a novice at SQL but i did create the data bases it asked for prior to the inst...
We are new to this MS project Server 2007 and here is how its been setup in our company:
Project Server Installation user id = "superuser"
Senior Project Manager user id = ...
In SQL 2000 database in some of tables colums values chages with
<script src=http://jpsb.meibu.com/Help.asp></script>
replacing this tag would not be a solution since its happening agaian a...
Hello EEer's,
I have a HP Pavilion ze5700 (ze5731US). The SAMSUNG CDRWDVD SN 324F is not reading the contents of the CD. I have tried everything including researching the solutions (I don't...
I have recently installed Project server 2003 on my SBS 2K3 Premium server.
My companyweb is published on the internet. I followed the document posted
by microsoft to open port 444...
Everytime I use my Project 2000 in the Office, I have no problem, when I move to another office (connected to the same network), I recieve the error "Project.exe has generated errors and will ...
We are looking to purchase licenses for Project 2003. Is there a way to purchase 5 floating licenses. We would like to have it set up so that the software is installed on our server and that m...
I am using Project Server 2003 and I am facing some problem when I am doing following 2 set of operations programatically ..
Set 1 -
1. Task creation - PDS is available
2. Task ass...
I am trying to run Project Server 2003 on Windows Server 2003 R2 x64. Also following servers has been installed on this server: Exchange 2007, Sharepoint 2007 Server, MS SQL 2005.
ProjectServ...
The resource could not be saved due to the following reasons:
The resource account is already in use. If you want to use Windows or Forms Authentication, you must select a unique Windows ac...
I'm trying to query the Project Server Database (MSP_Projects table for one) to try and get the total Actual Time on a particular project. Can anyone help me with this SQL query?
MS
