Hi Guys
I just start to work with Acronis True Image Echo Server and I understand that if you take a complete image of your server you can deploy it on a virtual machine. I guess I can create...
I am looking for a calculator or method to calculate the IOPS for a given drive, i.e. 300GB - 15K - 4GB Fibre Channel Drive or a 146GB - 10K - 4GB Fibre Channel Drive.
I would like to deplo...
Please convert the following KB to GB:
1) 4,509,578 KB
2) 6,817,175 KB
3) 722,922 KB
I have an image of a server Windows 2000. on Acronis universal restore.
What I need is to be able to run that image without having to format my machine.
meaning that I need to run that image...
i cannot use this usb drive because it just says there is no disk in the drive, whether i'm trying to copy a file to it or trying to format it.
xp goes thru all the installation process and...
Does anyone know where I can find the Serial ATA (SATA) driver for the Fujitsu MHV2080BH?
I am trying to suggest options for a SAN storage array for a client. Customer has asked what % performance increase is there going from SATA to SAS drives in a RAID array, in order ...
We have a Win2003 STD server using MS Initiator to connect a 2TB Thecus N5200 NAS box. For the last few days, we're getting a lost connection and we reboot the server, and this resolve...
I have a brand new Dell 2950 PowerEdge with the integrated SAS 6/iR controller. Currently it has 4 hot swap 500GB SATA drives connected to the controller. My question is can I remove these dri...
We have an out of warranty Dell PowerEdge 2800 server running Win Server 2003 with the following embedded RAID controller: PERC 4e/Di. Here are a few of its specs:
RAID BIOS H435 Build Apri...
Dear,
I have Dell Poweredge 2950 server with (6x146GB) HDD, Iam want to use this server to installation windows server 2003 ENT.
i have two controller, controller0 have four HDD and controll...
I am trying to add a new server to our existing SAN and not sure how to find out the WWN of the HBA.
Environment Windows 2003 Enterprise
Hitachi 7500v Servies SAn
Spherion 4500 Switch
I am configuring a new HP Proliant DL360 G5 Server and when it comes to hard drive performance I am questioning what is more important. Does going with a Dual Port SAS hard drive at 10,000 RP...
I am trying to find a solution for my company. Currently we have physical servers with 15,000RPM disks.
For performance, what is faster and reliable...
Booting up from a 15K SAS disk or ...
In need install RAID 1 for my computer , win 2003
I have 2 HDD SATA2 750G, 2GB RAM
My main: Asus P5GC:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=498&l4=0&model=1867&modelmenu=1
Raid 6 vs. Raid 10 for Exchange using SATA II drives on ISCSI SAN?
We are about to dump our old pop3 mail server (Raid 5) in favor of a new Exchange 2007 system for our 500 users running ...
Experts:
I'm actively researching and designing a SAN implementation for my work. Put simply I have a File Server running Windows 2003 R2 and an Exchange Server running v2003 SP2 Enterprise...
I have a Gateway MX6025 Laptop that is showing in device manager that it is missing the mass storage controller. I've tried looking on the gateway site, but they only have an intel chipset dri...
I just installed a Promise RAID controller card. Does anyone know the default username and password for the Promise Array Managment software? Thank You
Hi all,
I know that sounds seeems crazy but as small company we are looking for a Free or very Cheap VTL software that emulate Tape library from a client backup Software.
I have been loo...
have a [Compaq] storage array to our HP DL380 G2 server (running Microsoft 2K Advanced Server with Cluster Services which has a Smart Array 5i Embedded controller . In the array there are (3)...
A few months ago, I was trying to copy data to a CD and it failed (I don't remember why). The next time I started my computer, there appeared a "pop up" message on the task bar stating that I...
Just wondering if it is ok for me to stop this service?
According to Dell's Diagnostic Utility, I cannot scan my RAID Controllers and Disks because of this service. it recommends I turn it ...
I can't add a target portal using Microsoft iSCSI initiator on Windows XP. I've installed the MS initiator (version 2.05)on an XP (SP2) desktop and I'm attempting to add the target. I've ente...
Hi, anybody got these running nicely?
I have to setup some EVA 4400 SAN systems. I am looking for "best practice" guide notes or any tips to get the best out of them. SAN config/layout/al...
