What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Top Hardware Firewalls Solutions: 1 - 25 of 254
I just installed a new SonicWall TZ 100 Total Secure UTM firewall router. I used the install wizard and it seems to be working fine. I am unable to figure out how to configure VPN. Our ...
Hi, I have an asterisk server and would like to register a SIP trunk. I need to allow SIP through the ASA. I setup a port forward for TCP/UDP 5060 but it doesnt seem to work. Would an...
I have a Cisco ASA 5505 running version 8.2(1) I'm trying to set it up so to connect using the "Cisco AnyConnect SSL VPN Client"; I am currently using the predeployed Windows version 2.1.01...
I have been configuring pfSense on a test network with a new VLAN setup I need to migrate to.  I intend it to replace our current firewall solution which is not capable of handling VLAN traffi...
In GNS3 when I drag the PIX firewall icon to the topology window I get a message saying "Please configure a default PIX image" I have tried the following PIX IOS images: V6.34,V6.35,V7.22,V7...
"No translation group found for tcp src outside:10.10.1.14/49317 dst webdmz:172.21.0.20/8080" error message. I'm an MCSE but a Cisco newbie, ASA's are a month old now. Using ASDM GUI as mu...
Experts, I have a cisco voip gateway which has its voice VLAN 10.1.1.0 and data VLAN 10.2.1.1.  Its IPs are 10.1.1.1 and 10.2.1.50.  I also have an ASA 5505 which is our firewall/gateway to...
Hey Everyone, I have a ASA 5510 which I am setting up at the moment. It has two internal networks (data, and voice) connected directly to the ASA. At the moment both networks can go out t...
when copying over the file pdm-304.bin from tftp to flash I get the following error: PIX501# copy tftp flash Address or name of remote host [0.0.0.0]? 192.168.90.20 Source file name [cdisk]...
I need to add a rule to our ASA5505 that blocks all outbound traffic on port 25 (SMTP) except to our mail server which is outside of the network. The IP address of our mail server is 24.248.XX...
Hello Experts - Management wants a monthly emailed report on when people connect to the VPN and for how long?  Is there a low-cost (free) way to set this up? Thanks in advance.
Hi, I have a Juniper Firewall NS5GT-ADSL device in place on a WAN VPN. Clients access the VPN through the Juniper Firewall. Most of the remote clients work fine, but with two of the clie...
I am trying to setup a ASA5505 in in place of a Linksys router. I have dsl with a static ip address. I have checked with my isp and the modem is just a pass=through to the gateway, the dsl c...
I have a new SonicWall TZ 100 that works. I ran the wizard for port forwarding 443 to my OWA server AND the setup for SSL VPN before realizing that you can't do both. Remote users cannot acce...
Hello all, It's been a long time since I've had a scenario like this, and I can't seem to remember all of the steps to get my web server working. Here's the scenario: I have one public ...
Hi all, My situation is the following: I have 2 Juniper SSG5. With an VPN tunnel between them. intern A: 192.168.1.x intern B: 192.168.0.x the tunnel is operational. I can ping from ...
The network environment is DSL modem connected to Pix501 which also have 4 port switch built in. The pix is also connected to a Cisco cat2950. I delete the config, clear flashfs on it, and re...
Hello, Would there be any reason why an out of the box ASA configured as follows, should not be allowing internet access? outside, sec 0, no shut inside, sec 100, no shut No access-l...
I have an ASA5505 and am trying to set up a second FTP port. Unfortunately I am unable to accomplish this task. I have an active FTP server/connection on the default port 21. The alternate por...
I just installed a new SonicWall TZ 100 Firewall Router and configured it using the wizard. I cannot seem to figure out how to configure content filtering. Our  previous Snapgear was pretty e...
Greetings all.   I'm having a small issue with NAT in my ASA 5505, trying to connect to Xbox Live (there is another post similar to this on EE but it fails to answer my specific question). ...
I have a pro 2040 enhanced. We are using CFS to block content on most computers, there are some computers where the CFS is way too restrictive for the users to do their job and those IP addres...
Juniper 5GT - Firmware 5.0.0r8.1 (Firewall + VPN) We have 2 servers with 2 network connections each with 1 used as the dedicated IP address for the server and the other for use by NLB. Se...
Hi, I'm new to th ASA 5520 firewall and have a problem i can't seem to solve, so i kindly ask your help and expertise. My setup exists out of an outside interface with a /23 IP block th...
I am trying to configure one of our Inter-Tel 5000 Series phones for use outside of the LAN.  I have setup a MIP on our Juniper SSG-140 that maps one of our external IPs to the Inter-Tel box o...
