2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Time Tested Document Imaging Solutions: 1 - 14 of 14
  • 1
Does anyone know of some free XPS editing software?
Within former versions of the Acrobat Adobe Reader, it was possible to open multiple PDFs with a fixed position of the windows. Within the new version 9, each PDF is opened in a displaced wind...
Hi, I have a Samsung SCX-4125F Printer/Scanner.  The software on the Samsung support page is crap as I can only scan on the flat bed scanner.   http://www.samsung.com/ca/support/download/supp...
I have created an Adobe PDF file that has a web link built in using the Link Tool in Acrobat. When one clicks on the part of the screen now where the link is, before the link opens, it presen...
Hi, as the title says I need to convert thousands of files to black and white to reduce their size.  any command lines utility I can use to do this?  some are colour and some are grayscale but...
We are developing an application to: 1) get the spool file; 2) generate the pdf from the spool file; 3) change the default printer (from virtual to a real one); 4) send the pdf to be printed w...
When opening up a .tif file, if they select Send text to Word..., it'll open 3 instances of Word and display an error in Microsoft Office Document Imaging saying "An error was encountered whil...
Hello, I am looking at adding some functionality to a web page which would provide the following: -The user opens the web page -The user loads a scanner attached to the PC running the web...
I need to be able to add a graphic (timestamp) to the first page of a pdf document using a jsp program. I'm using linux 2.6.27.7-smp, apache 2.2.11, tomcat 6.0.18 and I have PDFBox 0.7.3 if th...
I have been using a ImageKit OCX to develop a scanning/imaging application and have added the JPEG-in-TIFF file format. I have tried saving Scanned images in both JPEG and JPEG-in-TIF formats ...
I'm trying to find an ethernet-based Document scanner which will automatically scan multiple documents and drop the file on a network server (specifically, a domain controller file share over ...
Hi I am working with document imaging. I found that TIFF is big and not easy to work with  but still working with one file. While JPEG is mutiple files. What do you suggest me to do? ...
The multifunction device works great as is.  However, I'd like to add the ability for a user to make a color copy by scanning a document directly to a separate color laser printer.  The LaserJ...
Hello, I was given a DVD full of PDF files that were tagged with bookmarks.  I broke out these PDFs into individual pdfs using a third party tool, however there are some duplicate pdfs in the...
  • 1
