Top Font Software Solutions: 1 - 11 of 11
  • 1
Hello, I need to make a barcode and put save it to a WebPage to then open in a WebBrowser in Visual Studio 2008. I was thinking either using just a font or use something like an activex con...
Hi. I'm a typical Windows users of MS Word, Adobe Acrobat Pro, Photoshop, etc, and am looking for a program to better manage fonts. I have a DVD full of fonts that I've downloaded from the Int...
Hello, I am looking for a free bar code font 39 that recognizes the : sign. I downloaded extended 3 of 9, and some other ones and they apparently don't support that sign. Also I need the und...
Can anyone identify this font?
Hello, I would like information on integrating barcode scanner with a VFP 7.0 application. 1. I need to be able to print client ID in barcode font. Is it done programatically or by mere...
I have a handwritten font that has certain parameters built in that I want to edit.  eg when two 'e' appear together, rather than use the singular e's it replace them with an alternate 'double...
Please take a look at www.overstock.com.  Is the "verstock.com" a standard font? If so what is it? Thanks, John
I am using a font inside a PSD file I wanted to backup for future reference. As you can see on the attached image it is in the fonts list in photoshop and I can use it without any problems....
What is the name of the font used in this image? Thanks! John
Hi Guys, Greetings! I have a friend and ask me to help him create additional buttons.  But I don't know what fonts being used 'coz I don't have any PSD file for it. So, kindly refer t...
I have Delta Jaeger font used in my design but my hosting company doesn't support.  I have shared hosting. Can anybody tell me how can I install this font on the shared server.  thanks,
  • 1
