Display (entirely) pages and fonts within are remaining Very Large
Asked by Nanci252 in Font Software
Tags: Pages, Fonts, Display, Resolution
Working on a problem for an elder friend.  Dimension 2400 machine running XP Home, factory equip. as original.   She just surfs and reads/does emails.
Her problem is:   when IE opens  she has to scroll a Lot  to read across a page, and the words are equally over sized.
I adjusted screen resolution  (17"monitor, XP style, Normal fonts under advanced button, 1124x768  is what she Wants)......but it did not correct the size of an explorer page.  Her scroll bars  are still  giving her approx.   Half way across  bottom  or  sides  to have to drag the scroll for the page to be viewed in total.    She wants to  only have to drag the scroll an inch or two for edges,   not  the other half of a headline !!
I'm stumped.
I checked  all the settings  in   Display,   all the settings  in  Int.Options,  all the settings in Accessibility (just to be sure she didn't have some sort of Blind access.  running).   And also tried to correct the text size in the dropdown menu on IE under View.   Nothing seems to  shrink this HUGE-ness  problem.
Her machine is so lightly used it has no virus' (I keep her cleaned and tuned),  and  this is just an Annoying  more than  Functional   hassle.
I'd  just like to satisfy an 81 y/o woman  so she can enjoy her PC again.
Thanks in advance for any  pointers  I may have missed.   I appreciate the nudge.  I have often thought about something so long,  I just get tired of trying to figure it out.
Someone with a fresh outlook, just  might  turn On my 'light switch"  and  it'll  get fixed in a jiffy.
Thanks again.
Nanci
[+][-]10/14/09 02:39 AM, ID: 25568563Accepted Solution
Zone: Font Software
Solution Provided By: DansDadUK
