Right on my windows 2003 server some of the fonts are corrupted.
eg, the start menu at the top where it displays your user name is all gone weird and symbolic,
and some programs have r...
Monaco font (Mac system font) is exactly what I need - but on a PC. Any suggestions of how to find a PC version? I need a clean font with a slashed zero and a capital I with top and bottom c...
I am trying to find a font that has its characters 'sorted' the same as the Lucida Console font, but is more solid looking. As an example, in a DOS window you can select TTF version or non-TTF...
I need a list of fixed width fonts, which are both windows and apple standard distributions, if they exist.
TIA
I'm looking for a stylized font with a '40s or '50s look, something similar to FontDiner's Milwaukee Neon (http://www.fontdiner.com/menu_lunch.html), but in a script or italics format. This is...
I would like to create a font recognition system similar to WTF whereby a user uploads an image, and the system returns the closest matching fonts. This will be a project for school work...
I'm looking for an alibata font but not of only the pure alibata scripts but also of regular English alphabets with the alibata look. Please give me address of sites in the internet or inform...
Somewhere between January and now I lost my ability to load or view Open Type Fonts. The OTF fonts already installed function fine. Fontmanager returns an error that syas the files are corrupt...
I am looking for a free download of the metaplus font
I need to find/buy the font Metaplus.
Derek.
Need to know the name of this font or where to get it
http://www.condenet.com/images_magheaders/head_gq.gif
Does anyone know where I can find Arial 1 and Arial 2 download? All I can find are commercial version.
Does anyone know what the name of the font that the SF 49ers football team used to use? And where I can get it for my PC?
If you go to this link - http://www.sportsstore.com/sportsstore/de...
I need to install Helvetica onto my PC. Where do I find it to download. Not talking about Helv-Condensed.
I am looking for a font based on the handwriting of Leonardo Davinci, preferably in TTF format. I've tried all the font places I can find on the web. Sorry, I don't know the name of the font, ...
Im attempting to do a website for a client...his logo text is in the font "Monotype Corsiva". I can select this font fine in MS Word, but it does NOT show up in Photoshop 6 & 7. The font is TT...
Trying to install bar code font (skanfont) - it is not listed in font list/windows/fonts.
When trying to install, receive error that it can't replace it, it is in use by windows.
Not sure wh...
An office have lost the original installation file for a font.
how can I move the font from an existing PC that has the font installation to another new PC (both Windows XP)
I thou...
I am looking for a font that look like the '57 chevy Bel Air. If anyone knows where I can find this please contact me ASAP !!
Kirsten
fontz@mailexcite.com
I am trying to create a PDF from a document. Adobe Distiller says that it cannot attach one font I used to the document because the font is licensed.
How do I remove this licesing informati...
hi, If anyone can recommend a great looking font that symbolizes the nautical theme.
I have found one or two on a google search, but want something that is quite unique and easy to read fo...
Anybody knows where I can get Helvetica free?
Hi
What is the easiest way to convert TTF fonts to Type1 fonts and gets pfm and pfb so I can use it in PDF.
Someone asked earlier, "Hello,
I have recieved a pdf that uses the font "Interstate-light", I have asked for this font from our prep department. They use MAC's so they converted to TrueType...
I installed some TTF fonts and I can see them all in MS-Word and MS-Excel, etc. But then I copied the text to Photoshop, I realized all the TTF fonts didn't show up in PS.
I tried another ...
