Time Tested Paint Shop Pro Solutions: 1 - 16 of 16
  • 1
Hi guys! Hope you can, im a newbie to working with photoshop. Okay....what I have is the following: An icon image that I want to turn into a jpg (which I can do), but I want to enlarg...
Running a very good system with XP SP3, 500 Gig disk, 2 Gig Ram Paint Shop Pro 7 has been working OK for months. I installed the latest version of Paint Shop Pro Photo X2 and installed three...
How do I get Paint Shop Pro Photo X2 (download version) to install correctly under Vista 32 bit (SP2)? I have downloaded it and installed it on a clean copy of Vista. Install hangs and will no...
I have some photopraphs and would like to create a collage but I am not sure how to do it or what is the best program for it .. I have corel paint shop pro x  and adobe photoshop elements 4 .....
Hi. I am new to web graphics, can someone please explain difference between Paint Shop Prop X and Corel Draw X3/X4 ?
I am a complete novice using paint shop pro - other than the usual easy stuff. I have a number of photos and need to round off the corners. I have tried following some instructions that someon...
I can't get my Paint Shop Pro XI Update working with Vista. I get as far as the "update" button on the update wizard screen, but then it fails with: your update was not installed/uninstallatio...
Please see attached GIF. I want an image of a corner (quandrant), as attached, but I need the pink area totally transparent so that when I position the image over a background image the pink a...
I used the product in the past but now when I try to start it it doesn't load.  I get the hour glass but no startup screen.  Cnt'AltDel shows it running (8140 K +/-) but that's the only sign t...
I can create and save gifs with transparent backgrounds no problem. When I open the saved file, it appears with either a black or white background. I would like to view the file with the or...
I've seen tutorials for Paint Shop Pro all-over the Internet concerning web graphics like backgrounds, buttons, Text, etc... Q. Is the newer Paint Shop Pro Photo any good for web graphics? ...
My Paintshop Pro X suddenly won't open. Running on Windows XP SP3. The only change is, I had Norton 360 installed. I know the tech came in and made some changes in msconfig. I uninstalled a...
Hi (Please refer to attached image) Using PSP X2. I have an image with an added rectangle (raster layer). How can I fill the rectangle with either a pattern or a very light grey colo...
Short version of problem: I can't view the transparency of transparent gif-files when working with them. Longer version: I have several transparent gifs that I want to modify, but keep run...
It possible to crop (reframe to reduce size) a jpg picture in MS Paint? Please advise how. Thanks.
I have a Canon XTI digital camera and own paint shop pro XI. Can I accomplish the same things with PSP than you can with PhotoShop? Would it be worth the money to purchase PhotoShop also. What...
  • 1
