Hi:
I'm looking for some tutorials of image transition effect in flash MX. Or if you know any cool effect (not alpa fade effect), please let me know (step by step tutorial if possible).
I am using Flash 8 and I am building a flash stock ticker. I want to change the color of the text based on change of the stock (positive or negative). I have created a text file using aspx and...
We are running a Windows 2003 Server with Terminal Services. Having trouble getting flash player to work for users. Have installed as an administrator but it still requires users to install th...
I've read the tutorials and posts at Adobe but can't get this to work. My url passes this to the page with my.swf movie:
Code:
http://www.etc/myswf.html?var1=3&var2=A
var1 a...
hello,
i need to make a a scroll bar that will show clickable images with dynamic images
how should i do that
I'm not an expert in Flash, but I definitely had a working understanding of earlier (AS2) versions. The new changes in Actionscript 3, though, have me completely confused on things ...
Our users do not have local admin rights to install Adobe Flash. Instead of going to each workstation to install it, does anyone know if Adobe has an MSI installation file to install Flash wi...
For some reason my flash movie will not load. I right click it and I see the following
"Movie not loaded" it is greyed out. I can run this same .swf file from my local hard drive, ...
I am trying to update a portable PC to Adobe Flash Player Version 9,0,124,0.
I get a message that says the installation was successful, but I cannot see any videos.
I am trying to open up external (swf's and jpg's) within a flash window once I press a button. I have created a loader and open the file within a MovieClip. The problem is... It does not scale...
hi
i have a form that should send post variables to a php file. but when i try to send them i can trace them but i get this error message in the output:
TypeError: Error #1006: value is no...
I'm using Flash 5. Is there any free tool that provides SWF to FLA conversion?
Rosh :)
I need to declare a global variable in Flash CS3 using ActionScript 3.0. I looked around the internet and the only solution that I found was to declare it in an external Class file, however, w...
does anybody know how to make a horizontal image scrollbar for my custom garment design page. This whole features is completely in flash. I know how to make a horizontal image scrollbar...
I have an movieClip with an instance cercle on my stage.
I want to duplicate it. I tried:
var mc_mc:MovieClip=new MovieClip();
mc_mc.addChild(this.cercle);
mc_mc.x=100;
this.addChild(mc...
What is the command in ffmpeg to convert an avi file to an flv?
I have an flash exe file start.exe I don't have the source code for this.
I want to open this file in my index.html
Is that possible? If yes, how?
Note: I create html files using Dre...
Hi all,
I'm looking for a standalone program to convert PDF files to Flash PageFlip files, similar to 3D Issue Manager:
http://www.3dissue.com/digital_magazine_manager.htm
However, they l...
I am creating a pretty complex application in Flash CS3 with ActionScript 3, and on several MovieClips I place a stop() command on the first frame to keep the playhead from advancing once the ...
I have some data dynamically coming from an Oracle database into an SWF flash chart. I want to give the user an option to click a link, which will open a PDF file containing the chart with da...
Hi there ppls, i have obtained the following actionscript, it all works nicely...what happens basically there are numerous pictures that rotate in a 3d gallery....the rotation occurs horizonta...
I am working with Adobe Flash CS3. I want to create a slide show of photos where the users pushes a button to advance to the next photo.
Chuck
How can I make my background transparent in flash cs3? so i can see the web page behind the flash document?
US-CERT recently released an alert for Adobe Flash Player, saying "There are critical vulnerabilities in Adobe Flash player that may allow an attacker to take control of your computer."
T...
I'm trying to figure out how to make some small text changes to my website, but don't have any experience doing it. I've managed to figure out that the file which needs to be changed has an S...
