Time Tested Web Graphics Software Solutions: 1 - 25 of 679
Hi all Where can I download MS Paint Im using Windows XP Pro but lost paint some how.. Thanks Aura
How would I go about opening a file for use with the extension .pub if I do not have the program (Microsoft Publisher)? If unable to open the file without the program (Microsoft Publishe...
For our new website, I need a close web match to the PMS colors on our letterhead and other printed matter. Is there some kind of algoritm to convert one to the other, or a website matching PM...
I have a CorelDraw (CDR) file that I want to convert to a bitmap, but I don't have CorelDraw, or know anyone who does. I've tried importing the file using Word 2000, and it comes out corrupted...
I have a coreldraw file which i want to convert to a bitmap file, i read the solution provided but there someone has converted the file & given it to the user. Could you tell me of some FREE s...
How do I open an ".eps" file.  Can I open it and save it as another format like gif/jpeg?
Anyone know how I can convert a .ai file extension so that I can view the graphics? How can I change it to a .jpg?  Or is it even possible to do that?
I have a graphic in both JPEG and BMP format that I need to improve the quality of.  I was told that I need to increase the DPI to 400 - 600 DPI, or convert the image to Vector format.  I've b...
Hello EE,    My HD crashed and lost its partitions. I used a program to restore the partitions but I could not get the drive to show its contents in windows explorer or in DOS mode. It wa...
Where can I get a nice free "progress bar" animated gif that can be used commercially? Thanks!
I've been given the following colour reference (apparently used in paint mixing).: NCS (Natural Color System) S 2020-G (Scandinavian Colour Institute AB, Stockholm, 1995 Edition 2 QL1). ...
dear experts, need this urgently. How to convert an ai file (illustrator) to a cdr (corel draw suite 11)?? I tried to change the ai file to eps, and import in the corel draw, but it is not edi...
do you know which application can open emz file?
I have made 3 hours of home VHS movie and want to burn it on DVD or maybe on VCD. I have put the VHS video on the hard disk through my TV card (Medion TV Tuner 7134). It makes MPG files of 2...
How do I create HTML table with round border frame and drop shadow effect? Can someone provide me with a detailed tutorial?
I have a .PMD file, I need to convert it to photoshop or any other editable format, please let me know...Thanks.
Can this be accomplished?
Can anybody tell me what the equivalent RGB colors are of the following PMS colors: yellow: PMS 131 blue: PMS 2767 red: PMS 187 More points are available if one can point me to a site ...
I'm looking for a nice 1280 x 1024 wallpaper. Preferably colourful and most likely rendered. can anyone suggest a suitable site where I might find such delights for my monitor to feast u...
I have an rgb color (r=108,g=147,b=108) that I need to get the best conversion to uncoated pantone but don't have access to Photoshop or equivalent program.  Can someone convert this color to ...
Anyone know where to get a AVI to quicktime converter? (windows system)
How can I open corel draw files using other graphic applications?
I'm wondering whether a tool exists to get a small animation/video in MPEG or AVI format using my JPEG files as "input". I'm working on Windows XP/2000. Does someone know such a tool? Thank ...
Does anyone know if there is a viewer available for InDesign files?
I created a vector graphic with a corel draw 12 tryout, then decided to buy adobe creative suite 2. I no longer have access to corel draw. Is there any way to open the .cdr file for use in ill...
