How can I open corel draw files using other graphic applications?
Does someone have experience with developer tool (not end user application) that can convert EPS to raster such as JPG/GIF/PNG?
I need reliable and stable developer tool that:
Support Full...
I was sent files in .emz and .mso formats and have no idea what software to open them with. They are supposed to be photos, but microsoft imaging can't open them and windows just asks me to ch...
Greetings,
How can I enlarge a jpg image I've downloaded from the web to use as desktop wallpaper without distorting it?
Can you tell me the conversion of pixels to inches?
Hi Folks,
Im using Photoshop CS3 and im trying to save some images with a transparent background so that I can import them into other files without that unnecessary white background comin...
Is there a media player that can play mpeg and avi files in slow motion?
I have only RGB or CMYK color codes for my 2-color logo, but my printer needs PMS codes. I do not have access to Photoshop. Can someone convert either of these for me, or point me to a tool th...
Is it possible to view AVIs which have been encoded with proprietary codecs? Eg AVI grabbed with an ASUS VGA will play *only* on that particular machine and it's software will not allow saving...
Can anyone recommend a single reliable and stable file viewer for ai eps cdr dwg dxf psd jpg bmp tif files (PC based)? I'm looking for something to view these file types larger than thumbnails...
I have psd file in photoshop and want to make icon from that file. Programmer need gif/jpg/png format file. But when I made gif file which has transparent background then it shows cruked outli...
For the Holidays this year, I want to make t-shirts, posters and the like. I've purchased a lot of copy-write free clip art and photo graphs.
Specifically, I purchased Hallmark's Christian...
A friend can't view some of his photos. Irfan says "can't read file header! Unknown file format!", Windows Picture Viewer "no preview available". Checked and found 41 consecutive folders with ...
I'm looking for a video file converter. I have MOV files (QuickTime) and I want to convert them to MPEG files on a Windows box. I'd also like to be able to edit the MPEG files, like add specia...
I have multiple softwares, including the Studio MX Suite, Creative Suite 2, freeware such as the GIMP2, and others... yet I cannot figure out how to resize an image without distorting it. It ...
I'm looking for a *FREE* program that will allow me to view different graphics files (such as EPS, AI, CDR, etc) without importing them into a graphics program. Any ideas?
I have several files with a .mix file format that I need to convert to .jpg. I don't have Microsoft's PhotoDraw or PictureIt, these programs generate .mix files by default and would have allow...
DOes anybody know how to convert an EPS file or DXF file to CDR (Coreldraw file)? Is there any application which does it? Where can I find it?
This may be basic stuff for you guys, but please help me out! I have a 4 megapixel Canon SD410 camera whose pictures at the highest / finest settings takes jpgs that are about 2 meg in size.
Is it possible to covert a PSD file to Illustrator? I don't have the software Illustrator, just photoshop and flash. Also, what is the file extension of Illustrator?
Hi all
I am trying to find a formula the can convert RGB to CMYK. I already have tried the below formulas and they seem to produce the correct results for what the authors say will be produc...
What is video bitrate?
The higher file size the better?
Any site link w/c can further explain?
Could anyody suggest me some good free Indesign template source on the net. I have to design a professional looking 1 page pdf. I have Indesign CS2. Would like some lively templates wit...
I am looking to make a clear glass bottle (kind of like a vodka bottle or bacardi bottle... wine bottle shaped) in either photoshop or illustrator. I would prefer to have it as a vector...
I received a file from a large client and the file extension is .zdl
What can I use to open this file?
