I have had a green screening Codec problem for some time now.
These are quite a few articles on EE, which have tried to fix individual problems. I have tried the suggestions in quite a fe...
I saw an inexpensive "camcorder" from Canon (Audiovox DC400 MPEG4 Digital Video Camcorder at
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=getItemDetail&Q=&sku=332786&is=REG&si=s...
Hello all experts,
I cann't find a good website where i can get RC helicopter images(Remote control helicopter).
Would someone give me a link or something where i can get free rc helicopter ...
I've always had a problem playing video clips since I upgraded to WMP 9. They crash the computer after playing. I don't have a similar problem with Realplayer or Quicktime. I have recently ins...
I have been given the project to research face regonition
Here is example of what I am looking to do:
take a digital picture, be able to automatically Crop and center the head, and be a...
I have been frantically looking for an rgba colour picker--one that would in essence allow you to preview rgba colours. I am trying to get the right values for a development project and trial ...
Hi Experts
I have read that to make images clear when resizing they need to be converted to vector format.
I have read about the software at Adobe and Corel Draw and they do not make it clea...
Can i get an algorithm or source code to convert BMP to GIF and JPEG picture formats ?
If so, how can i get the algorithm or code ?
I need to write an algorithm that determines the position of a shadow underneath a ball when the light source is directly above the ball and the view is top down.
Picture a top down football ...
I tried making an avi file to place in an application I am making using the MFC library. The problem is that it won't show up. I tried one of Microsoft's avi files that came with windows and...
Hi, All:
Suppose I have several points marked as '1' within a binary image. I want to find the minimum distances b/w each of them(that is the min # of 0 pixels b/w them) and find the minimum...
Can anyone please explain what is a candle graph and how it is drawn?
is there any software that can convert a asf file to avi or quicktime format? Convert to MPEG is also OK.
i need a way to convert a pdf to tif using the adobe reader.
some faxserver are able to do this, but i don't know how.
i look for a method to deliver a pdf to the reader and receive it a...
"I have been writing a program to plot graphs on and off for several years now since I first taught myself to write a function parser around 1983. I recently decided to try a really big update...
I am creating pop up menu's with fireworks 4. There is only four fonts to select from, how do import further fonts in this area?
regards
pete
This is really bugging me...
When I insert an image into Word, one that I've created, there is a faint pink screen around it. It usually occurs with tif images - something that I've created i...
I took some pictures on Multimedia card of my digital camcorder. The size of the picture is 640 X 480 pixels. Camcorder can take still picture only upto 68,000 pixels and hence qualit...
i want to export a character created in 3dsmax 3
along with its bones and hirerchy into poser... is there a way ?
I use the acdsee image viewer programm which is excellent.
But I cannot see .cmx images.
Is there any plug-in for this programm in order to see .cmx images?
Or any plug-in for other known g...
hello everyone! how can i exactly snap vertices to grid intersections? i've tried turning on the snap options and setting the snapping power from a range of 1-8 but it still doesn't snap perfe...
I often take hundreds of high quality JPG photos with my dig. camera. Each are ~1.4 Mb in size at really high quality - great for printing but too big for online posting.
I'm looking for an...
Hi this is driving me nuts. I have an SVG file loaded in Adobe Illustrator CS2. Its width is 1728 pts = 24". I am trying to export this to a JPG, but when I look at the resulting file, only a ...
I am working on a simple logo. It consists of vector line art and type that I have converted to outlines. It is an .ai cs2 file. I need to create an .eps file for commercial printing. ...
Where may I obtain the Visio 2000 SR-1 update package? It appears Microsoft pulled it from their site on 1/1/2004.
Best,
DrJekyll
