Hi there, I have recently purchased a Toshiba 23HLC56. I purchased the TV with plans to use it as a TV & computer monitor. The unit has a resolution of 1366x768, however according to the use...
I want a script that can reduce the size of all picture files in a folder to 10*10 size.
and then put all those small images to a word file.Insert all picture files in the word file th...
I need to create a menu where as you hover over a button it changes color. So essentially a new button is swapped in it place. Problem is, there is no definitive veritcal line seperating the b...
Hi
When I type text in photoshop and I save as a gif or png or jpg, the text seems distorted.
how would I save the text as clear type?
We have a series of data tables (listing various countries down the left, and several columns of criteria across the top) that we have created for a research website we are building. The table...
I created a bunch of gif file for buttons for a web page using a program called Cystal Buttion. Right now
half of the buttons are 210 X 46 and the rest 220 X 56. I would like to make them th...
Is it possible to configure gallery2 to allow people to add photos to basket etc, without needing to register and login?
Many thanks
I hope this not a dumb question, but I REALLY like the graphics on this site. What Graphical Software was used to create all the buttons, tabs, graphics, etc. on this site (ExpertsExchange) ??...
Please give me your thoughts/criticisms/suggestions on this website design:
http://tinyurl.com/5vtt22
Specifically the design, layout, colors and general look and feel.
Would like to ...
Can anyone tell me where I can learn to create backgrounds such as the one shown here
http://joshuaink2006.johnoxton.co.uk/
I could take the code apart I guess, but does anyone know where ...
Hello Colorists!
Thanks for reading this question! If I have found a really pretty pastel green. Is there a way to convert it to a corresponding pastel blue? Some kind of formula to re-w...
Is there a Freeware to extract for ex. seconds 1 to 19 from a 20 sec. .MOV ?
Or to extract sound to .WAV for editing then back into the .MOV ?
Regards,
PhL
Does anyone know how I can take a given font, and hollow it out so that only the edges are showing?
I tried editing the pixels in Photoshop, but I couldn't get it to come out clean....
Hi, all
I received a file with extension .fh9.bin
It should contain FreeHand 9 file, which is compressed, I think.
How to unpack it, is there anything like Winzip for .bin files?
Or ma...
Hi there,
I am interested in using a program out there which can produce sexy Procedural Maps on my plain Bitmaps such as Maps that resemble rock like faces, bricks, etc...I saw a program c...
I have been having a problem with playing AVI files on windows media player. Windows Media Player will attempt to download a codec to play the file, but will result in an error. Only ...
I am able to generate the following 3'D CHARTS using the Dundas's 3D CHART SERVER.
1.Line chart
2.Bar chart
3.Pie chart
My Doubt is :
1.Want to rotate the chart along the X-axis,Y-axis an...
On 22/12 there was a question about "avi problems".
I think i had the same problem, but with a different codec.
What I did :
- Recorded a movie.
- Digitalised it with the sor...
Specs:
CPU: AMD700
OS: Win98se
Vidcard: Voodoo3500
RAM: 384
HD: 30Gig & 40Gig
I just installed 3D Studio Max 5. When I start up the program I get the splash screen and I see it load...
I only have 16 colors in display properties....i don't know what to do to get the right amount of colors. I had win 98 and upgraded to windows ME. Someone built this for my youngest daughter t...
I have produced a large poster design in Illustrator 9, using the RGB colour mode. However when I change to CMYK mode, all of my colours change. Could somebody tell me why this happens ...
Hi does anyone know of any vector graphic resources at all on the web. There are plenty of stock photography sites, but no one seems to offer similar collections for vector graphics. There mus...
I have models created in Maya, and now I want to be bale to include these models in my CD-ROM for the client with the VR ability. That means that the client shd be able to view the models with...
I am trying to find a business solution for saving digital (employee) files in tif format. We currently have a few thousand that are already saved in PDF, so I am lookikng for an image ...
I've got an .avi that I want to put on a CD, but I'm about half a MB short on disk space. I don't care about that part, its just credits. The video editors I've tried like Ulead and something ...
