I have the latest ImageMagick installed on my server and I'm trying to figure out how I can take an extracted matte image (grayscale) and convert it to black and white in such a way that all p...
i know very little of computers and software. I need to open an attachment that is a max file. However when I try to open it it tells me i cannot. I need a way to convert to a jpeg.
some f...
I have Illustrator CS2 for the Mac, and I have a rather small vector graphic on the page. I am at a zoom of 1,000% and so when I use the warp tool it is far too big - half the size of t...
Is there a way to create a gradient with a transparent background in Photoshop CS
I need a free sprite maker for a game I'm currently developing (I can't release a name). It has to be free, and workable on Win98.
Thanks much`s!!!
Hi. I have too many *.jpeg files with 75 dpi resolution
Now I want to increase it's resolution to 400 dpi in
batch processing..
Individual increasing is possible in Adobe Photoshop.
But ...
I'm looking for software which can create guilloche (e.g. those that can make vector pattern work for background, like money, certificates etc. have)
I'm looking to redraw a logo in Illustrator I had originally worked up in Photoshop, but this is my first real outing with Illustrator. I want to get an inner bevel effect on some text ...
I am new in Corel Draw (never used before).
I need create vector label for printing, simple enough(exact size, rounded corners, contour need be marked for cutting out). Barcodes can be import...
I would like to ask how to make panoramic images with 360 degree in 3dsmax? I have tried to use the option for exporting panorma, but the output images are not 360 degree.
It is perfect if ...
Anyone know of free software that checks for the DPI of an image? If not, does anyone know if Photoshop Elements has that ability?
Thanks.
Is there a way to convert CorelDraw files directly to a verison 12 DXF file?
Oddly, Corel only has DXF export filters for versions 9,10,11,13 and 14. So we're currently having to export as...
Hey!
I am planing to make kind a old-looking treasure map.
What I am looking for is a illustrator burush which I could make borders for land. I want something similar as seen on picture...
Hi. Somebody mailed me some files which are supposed to be graphics, and they are called image.sig. I cannot open them in any graphics program, and i tried changing the extention to gif and jp...
hi there; i'm looking for sites that sell high end, professional flyer/brochure/booklet templates.
again, high end and professional material such as, www.stocklayouts.com.
thanks all.
I want to try toon shading, but it is confusing me. Can someone give me some tips, and help, so I can finally get some good results? I am looking to toon shade a scene, and then render it out ...
Where can I get a specification for the .DXF file format that is used to transfer drawing data between processes?
Hi..I just received an error messgae trying to launch Quark Express.
"The application preferences file is damaged.Please remove it and re-launch QuarkXpress. (293)"
Can anyone help me?
How do I convert a .art file to a .jpg file?
Hi All !
Is there a way that we can insert a Java applet in powerpoint presentation ? If there is Please let me know the Chronology....!
Thanx
I have about 30 gif's animation which i need to resize to the same size,how can i do it
by keeping my animations,is there a free program/technique?
I ned to save them again after the...
I have a logo that is very simple in shape on a white background. The logo has a drop shadow on it.
How can i get rid of the white background to make the logo transparent while keeping the...
Hi All,
I have an online photo gallery of my friends and things on my webpage, which are in jpg format. I would like to be able to add "text in a bubble" over some of the the photos, to emula...
We have a data center on Oracle 10g and connect it to MS-Access 2007 by ODBC, All the reports has been designed on MS-Access 2007... Can I convert MS Access reports to html? is there any way t...
SEARCHING DESPERATE FOR A CONVERTER THAT MAKES .AVI FILES
OF ALL KINDA SORT INTO JUST A .DAT FILE.ALSO LOOKING FOR
A VIEWER FOR THAT .DAT FILE WITH UNLIMITED FILE LENGTH.
TARGET IS:CONVERTING ...
