Time Tested Web Graphics Software Solutions: 151 - 175 of 840
I'm using Windows 95 and if I save a .gif or .jpg file the icon will be the tiny windows picture, but when I double-click it the picture will not open up. It'll say Paint Shop Pro 6 can not be...
Does anyone know of a freely available QXD viewer and where i can find it? Thanks
Ok... I feel really bad having to ask this question, but I cannot find an answer to it. I am using Adobe InDesign CS2. How do I get the current date in a text field? I have a master ...
Please help me regarding this How to convert a .MOV (quick time file) to MPEG? Also For example if i have a 240MB .MOV file of and want to convert it into .MPEG and at the same time want t...
Hi I have a number of files that are in the .MIX format and i want to convert them to JPG. Is there any file conversion utilities that will allow me to do this? Please help. Many than...
I have been asked to convert about 300 .jpg (photo) images into vectorized format.. and the final output required is similar to a painting.  I am currently using adobe streamline and then taki...
If I saved an image in Photoshop CS2 (let's say it's about 20,300 KB), what is the best procedure to reduce it for the web AND maintain optimum sharpness? I am just trying to see if there i...
I would like an explanation on how to make an intro in Action script 3. I work well in 2, but I am completely lost in 3. I want to have the following: 10 movie clips - 1 on frame, 1 on ...
How to sync movie and subtitle in virtualdub? I am a newbee, so step by step explanation would be good :) when i download the subtitle and put in the same dir the dvd player can't read the su...
I would like to reproduce some realistic metal graphics such as those found at http://www.oakley.com (top nav bar). I have browsed through a bunch of Photoshop tutorials, all unsucessfully. I ...
I am using the AdobePS mac printer driver to create and eps. I want to use that eps on a pc-based system. I would like to find a program that will easily convert the mac format to the pc forma...
Hello, I am just learning Illustrator and have used photoshop for a while. I would like to clear up a question I have about flattening. Does this mean the same thing in both programs? I don't...
Hi, I want to "blend" or fade two images together. At the edge of each image/layer, I want each one to fade into 0% opacity, so they blend into each other. I've Googled this, but I can't fi...
Can anybody tell me how to place a duotone image into illustrator 9? I have already tried unsucessfully to place an EPS from photoshop. Is it possible to create a litho printable duotone ima...
My webpage has an embedded WMV file. I have designed it so that it doesn't autostart. This all is fine, except that.... At the moment it shows a blank white screen at the beginning. How do ...
I bought T-shirt Factory Explosion software and just found out it does not support gif images. Since most of the clipart I want to use to create t-shirt designs seems to be in gif format, is t...
Hello, I am working on a simple logo. It consists of vector line art and type that I have converted to outlines. It is an .ai cs2 file. I would like it to be transparent. I need to create an ...
We are setting up a new event at our site where peopel would donate for 30 days and we are trying to make our goal of some $$. I am looking to set up some kind of a manul meter in the page w...
I did this once about four years ago and I can't for the life of me remember the software I used.  I searched the net only to find I don't have a clue the keywords I need to be searching for. ...
Ok I have an image from designload.net and I want to add onto this image my logo.  When I place my logo on the banner my logo also places a white square where my logo is.  I want my logo to bl...
How do I change the DPI of an image I create in Paint Shop Pro to 300 dpi?  All it lets me do is change ppi.
Hi, I've created some cool metallic text using layer styles in PhotoShop, but I would like to export this for use in Flash as an animation, preferably as a filled vector shape. What's the prop...
Is there a way to turn off anti-alias on text in Illustrator CS.  Currently I am typing the text in Photoshop, turning off anti-alias, then dragging in over to Illustrator CS.  Wondering if th...
Hello,   This is a 3 part question: 1.  Can somone explain the difference between the various forms of codecs.      Specifically:      Microsoft Video 1      Indeo Video 5.06      In...
How can I put a graphic showing a daily countdown of days with the amount of days left showing on the page?  Example;  if there were twenty days left until the event a large 20 would appear  a...
