I'm looking for a vector to vector translation utility that will convert an AI (Adobe Illustator) to IGES? If not, how about DWG to IGES? or DXF to IGES?
Anyone know of a tool to convert CorelDraw Version 2 files to some other vector type? or even just read them. The Version 2 format is no longer supported by the later versions of CorelDraw, bu...
I have a small animation that runs 300 frames (10 seconds) All I want to do is loop the last 2 secs so in flash I would do a gotoAndPlay (240) on the last frame. How can I achieve thi...
do you know how to search for network folder with Picasa 2?
i need a color proof. but printing company said digital proof is good enough. do you think it's true?
what's the digital proof and how do i know if the true color?
i see the definition of ...
I have an ad I'm making in Illus CS2. I want to save it and I want to make sure it has a high dpi so that it will look good once printed out by a printer. However, I can't find the option to s...
I Just got me a Dell system, and I went ahead and tried an 18 inch LCD screen. Well, I don't like it do to the fact that graphics and multimedia don't look at crisp and clear as I thought. S...
I have a vector image that I am trying to add a drop shadow to and export at 300dpi for print media. I create the elements and add Gaussian Blur Effect to them. I then export as a PNG image ...
Experts
I want to know what is LUV color space? When we will need to use it?
How to convert it from RGB color space
Thanks!
Help!
I have a file in Quark Express. I have never used this file or program before. I am trying to get this file into photoshop so I can edit it.
I am trying to export to PDF, each ...
where can i get the newest drivers and what is the card cababel of and does it suport open gl its a onbord card has its own memory and is on a petiun2 pc100 motherboard and takes a 450cpu
I am working on my website and have incorporated a dynamic horizontal menu at the top and one of the menu has sub-menu's. Just below this menu is an image. Problem is the submenu appears beh...
I been having trouble when it comes to what I design and what the final result actually looks like. I design web pages and I have noticed that when I see my design on other computers, they loo...
Hi, all,
I am brand new to adobe illustrator. I am running illustrator CS2 on XP Home. I want to replace a color on a button, leaving the text intact. However, the button is a merged image...
Hey all,
I am a web developer so what I am used to is making all my graphics in GRB format at 72 dpi. I have decided that I want to design my own business card, and from everything I am se...
I have purchased a flash template to customize for a website. It has four opening images that have been sliced in a way I can not replicate easily or figure what program or feature was able to...
I have a gazillion graphics, both photos and clipart which are in the ccx format. (CCX was the format used by the now defunct Printhouse Graphics program).
Does anyone know of ANY conversi...
I have a number of files that I can not open in corel draw.
These were created a few years ago using Corel draw 7.0 on a PC running Win95 or 98.
I have re-loaded CDR7 on my current PC runnin...
I downloaded the winfax miniviewer on my laptop to view faxes that I recieve via winfax while traveling. (My laptop does not have winfax installed. Winfax forwards faxes via email to me from...
This is a follow-on question where I asked if it was possible to select gradient colours using the colour picker tool rather than the somewhat clumsy RGB spectrum (http://www.experts-exchange....
I draw one shape.. I can drag it around freely. I draw a second shape, lasso select both of them.. now if I try to move them, they won't do it. Why? If I shift-click to select both objects, ...
Does Corel Draw have a macro language? If it does have a macro language is it possible to import co-ordinates to draw rectangles?
I created a design in Fireworks CS3 and sliced it up. The table is 800 px wide.I have triple checked that the width of the slices and images total 800 px. I have removed all filters from the i...
I have been trying for hours to write the iptc data below to my image, the closest to success I have gotten was getting it in plain text into the image file.
I have tried the following c...
Using CorelDraw 10. Can I convert a RGB BITMAP drawing that has limited text to a CDR so that I can edit it with Corel draw? If so, how do I accomplish this conversion.
