Hi, I'm making a div that pops up over any other content on the page, I want the border of that div to have lower opacity than everything inside. I dont think theres a way to specifically make...
The top Home icon, About Us, & Contact Us links on the upper right of my pages are displaying exactly the way I want them to in Firefox, Safari, and the new Chrome browser from google:
http...
I have a div wrapper with coloured background and border. inside this are various other divs with text and image content. Everything was fine until trying on IE8 and the #wrapper does not...
This one is probably simple but with the struggles of ie6 this one has eluded me. I am not able to enter anything into a input type of textbox on this page from ie6. All is well in all other...
I have a selectbox with two values. Onchange I want to update a variable and then recalculate another. I think I have this, how do I change that variables display in the p[age without a reloa...
I have coded CSS to get our template to work in Firefox, which it does. However, when I test the page in IE, the positioning is way off. The template is very simple, a banner with a left nav...
I have a simple quesiton but can't seem to find another person who has asked this question. Can someone tell me how to have a JSF datatable or RichFaces datatable display the table where each...
hi,
I am making a website in which i am using background picture, but i need to fit that picture in any screen resolution.
thanks
narinder
I have the HTML and css as given in the code below (additionally, font-size:15px and line-height:18px are in effect in the containng <div>, just in case that's relevant).
The CSS contains no ...
I have a form with a select box with size 3. option can be more than 3. The problem is with vertical scrollbar, it always appears in firefox(not in IE) even option is less than 3.
I want ...
I need some help with the code below. I am trying to create a horizontal nav with images as separators and rollovers for the items. I have this working except for the space between the DIVs wh...
I have setup Virtual Box on Windows Vista 64bit Host and created a virtual instance of Ubuntu Server 8.04LTS - I have been able to configure the virtual network adapater to communicate with th...
I am a attaching 2 drop down boxes design and want to style them in XHTML/CSS. I am unable to do that. Searched a lot but couldn't find solution.
Please help me to figure it out !
Thanks...
I am working with JavaScript programming... (as opposed to "Java", a Sun Microsystems product).
I've found that JavaScript ALERTS, are possibly the only means for doing what I want to do.
I...
Hello. I am looking for a way to avoid breaks in rows when a table spans across multiple pages. The browser that I'm most concerned with is IE8. I've tested out page-break-inside:avoid, but...
I'm having a problem with widths on input[text] fields in IE
In IE, it renders the width as 100% + 10px. I cannot figure out a technique for constraining the width to the container.
I un...
I have an asp.net 2.0 application. I need to have a page setup with a header of 75px height width 100%, constently set at the top (not moving). A footer of 25px height width 100%, constently s...
@ http://tiny.cc/cTG8O I have a green tabbed menu bar to the left. The text is rotated in Firefox 3.5, Safari and Internet Explorer (IE8 not perfect yet..). For Firefox 3.0 I have not found a ...
I have this html form
<p><label for="site1">site1</label> <input name="textbox1" type="text" size="20" value=" "><br><br></p>
<p><label for="site2">site2</label><input name="textbox1" type...
I've written some basic CSS for a list, with a background image.
But the text's hanging indent is off. I want all the wrapping text to be flush with the text above it...
I am trying to implement a dropdown menu on my site and designed for it to work in Firefox and Chrome. In checking back to IE to solve all of the IE issues, I noticed that when you...
I am building a site that offers a high contrast view for users with limited vision. In theory, users can click the "high contrast" link on the top nav bar and all background and font...
I hate to have to ask this one, because the subject has been addressed. I did try all of the solutions and still cant make it work. So, how can i set these column widths manually.. They see...
Im having alignment problems for a website im working in different browsers. In IE7 Its appears ok. In Firefox there are two pictures slightly off including the Flash Marque.
In G...
I got on a page a bloc containing other blocs.
The main bloc is the one with a pink bg
First bloc inside it the middle picture
Second bloc inside is the text.
When I add the text, it...
