I'm trying to position a div element on top of a flash movie. Even when using z-index it doesn't seem to work. Is it even possible?
Go here to see what I mean
http://www.mybiblegames.com/community.php
The tests at the bottom are inside the same DIV tag as the top ten stats but yet the DIV box does not extend with them, h...
Hi all,
I am having a look at creating a navigation CSS section for my site. I searched around on the web and foud the below example(code snippet below)
it all looks fine but i need to d...
I have included a script that allows me to show my customers open changes that exist by the change number. To keep them from having to log into our ticketing system every time they want to vie...
How do i embed a font in an html page? A font that is not commonly used .
SHould work for both firefox and IE .. Please give the code (css??) etc also.
thanks
sid
Hi:
I am developing a blog for a customer. Please check it out and notice that the header is divided by a small frame which I am not able to adjusted to the header size which is 820px with ...
I am considering using an OSWD template for a new website of mine. However, the template has a small graphical problem when you view it in MSIE 7 (it's totally fine in Mozilla and O...
I have a web site builder tool where customers can build their own websites. I am trying to create an easy way for them to edit their left navigation stack. I have found the following code a...
I'm currently working on a site for a client and they want a CSS javascript dropdown menu which rolls over flash. I have made the menu and all but I cannot get the CSS dropdown menu to appear ...
I attached a jpg. Im trying to find some CSS that helps me create exactly as I created in photoshop.
Any suggestions?
I have exported a site collection and then imported the collection to a new site collection in a new farm using the same user profile and import from the same domain. I cannot for some reason ...
Can anyone comment on why the text-align justify part below does not work ?
thanks,
GISVPN
I am pretty good with CSS but this one has me a bit stumped. I have a page where, in IE7 only, my footer navigation (which is built with < li > list-items, inline w/ background images) sometim...
I've built a site that I've just been able to see in the context of a 1440 X 900 monitor. While my flash content is centered, the background image is not and I've tried several things to get i...
i made a rounded corner with my own images and copied css/html code.
I just tested it with a smaller image abd found it wont display as 1 image but 4 separate pieces.
the original had bigger...
I have one table above another on a page.
How do I remove any padding before or after each table, so that the first table runs right into the second table without white space?
The code is attached, How do i align the slider control to be on the same line as the textbox?
I've never use the STYLE tag. I came across the following STYLE tag with the CSS values wrapped in an HTML comment tag. Is that the norm? The styles seem to work if leave them in the commen...
In http://www.mexicodiscover.com/mainmenu-example.asp I am creating a vertical menu, but request solution to the following:-
a) how to give the second level (eg Mexico info/books) a different...
Hi Guys,
Can some one tell me if I doing this right and how I can change the width of th red box (the bottomliner) to be the same as the green header without the logo and be positioned on...
Hi
Could somebody please tell me if it is possible to import an external stylesheet into another external stylesheet, but only if the browser is IE?
Please note. I am not asking how to ...
I want to use some CSS files only in IE7 and all Non-IE browsers. So the CSS files should NOT be used by IE6. I tried using conditional comments but had two problems.
This one works, but is...
(If a picture is worth a thousand words, here are 2 pages which should be worth 2000.)
This page renders correctly in Firefox, problems with IE:
http://www.luthiercom.org/Testing123CssBack...
Hi I am new to CSS Positioning. I am creating a page in dreamweaver. I am applying a different style to each element on the page, with a "fixed" position, and using "top" and "left" indicators...
I'm learning CSS right now and am having a hard time with certain aspects of my top navigation. The account links across the top when you hover over them do not change the link color until you...
