Hi: Can any one please tell me how to i move the whole page to the center of the screen? I try to play with the css but not successfull yet
http://www.southeastneurology.com/testsite/
cs...
I have 2 questions here
1) I have a background image that has a very complex gradient because it fades from light gray at the top to a while color and at the same time the side of it fades...
Hi, I use dreamweaver cs3 and the area I want to edit shows up as being within a div tag. See attached photo of the area I want to edit.
Here is the page I want to edit:
www.cellprophone...
is there any way to make a div ( that contains some html information ) over a swf file?
i mean to say a div over a swf file in a html page?
I am looking for CSS code to make a list, the list is a set of links to different pages (must open in a new window) that is also horizontal - no bullets either. I cannot use normal files or...
http://bonnyriggplaza.businesscatalyst.com/home
This may seem like a very simple problem but I cannot for the life of me work out why in IE6 the paragraph text inside the DIV 'menu-cont...
Hi I am working on a site
http://202.162.96.29/~clean
On the left hand side there is a Agents login.
At the end of this module there is a "forgot your password" and " Forgot your userna...
I have a problem with positioning of wiki tabs on the following site:
http://efc-canada.net/crce/index.php?title=Main_Page
I need to move the article tabs down and can't figure it out.
Hi there !
So here is a page we did at school, it's very very basic as you can see but i however managed to not being able to place the footer correctly (it's the little tiny thing you see ...
My custom bullet is not appearing in my unordered list on my web page. I am using a separate css styles sheet and everything else on the sheet is working on my web page.
Hi, can anyone see what is wrong here:
http://stealth.development.idealogyltd.com/
changing to a php include to bring in the dropdowns pushes the div containing the image down.
this w...
Site in question: http://spigotdesign.com/
On the main landing page, I have a Flash animation of a dandelion head with seeds floating off to the left. The flash file is 2000 pixels wide so ...
I have a float within a div that and I want to make the div take up 100% height on the float but when I do that it doesn't really do much. It seems like it would be so simple yet it's giving m...
Can anyone tell me why there is a gap between the header of my website and the edge of the browser? and also how to fix this in CSS?
I've looked over and over my code and can't find where the error is lying, basically I'm trying to align the footer to the bottom.
As always it's working in Firefox but not Internet explore...
The borders on the following form are shifter one pixel to the left starting with the second box all the way to the last.
I need the boxes to align to the left and be the same width. ...
My page:
http://www.drayerconference.com
Looks great in Firefox, but is missing the content from the middle.
Below is the screen.css stylesheet.
I know that min-height does not wo...
I'm new to CSS and am trying to remove the vertical blank space between a drop down menu. I know that I need to add margin:0px; padding:0px; to my code but don't know where or how it s...
Hello I have a form like I show in code snippet.
I want when the page open or reload the focus for the box "textfield" (ready to write when the page open).
??? I work with .css.
I am trying to center the following unordered list withing the borders of the "leftbar" ID. I've tried several different things and am unable to do so.
Your help is appreciated.
I have a gallery that displays 12 thumbnails on a page. what I want to do is display a layer over the thumbnail onMousover that contains some of the image details.
I dont know what the be...
Hi, i am looking for a way to keep a banner on my site always visible. Basically when the user scrolls down on the page an event handler should deal with positioning the banner element to alwa...
I have a page where people can view their activity which is a table of data - some 25 to 100 rows. Problem I am having is that when user goes to print, it cuts off 2 to 3 rows at the bottom. I...
Can you add javascript instructions into a linked css stylesheet?
I'm unable to fill in "round-bottom" with orange fill. Could you please point out what I'm missing? I'm sure you advanced CSS coders can easily spot this one out. This problem is seen on my ...
