Top CSS Solutions: 526 - 550 of 731
I am creating a menu for the top of our new website.  I used Fireworks so I could "easily" get the menu to work on top of an image.  After a lot of struggle and some EE help in another thread,...
Could someone help me find a way to make a footer on a webpage which always stays at the bottom of the page, i would prefer it not to be part of the scrollable area. thanks in advance.
is there an easy way  to get a small symbol next to the hyperlink on a webpage eg bullet point, small square, small triangle or do i need to create an image and add this symbol to the image...
In my next comment I am going to provide a link to a page that is a recreation of a page that existed on another website.  The page includes tables, and also may not have the most optimimal st...
Hi, Is it possible to have a webaite layout to fit different screen resolutions...I realise that there are a lot out there, So what is the best solution when a client thought there website...
Hello, I have an issue, when I view my page in IE, there is a space after a validation check.. Other browsers seem fine.. Let me show you what I mean by images.  I'll attach the coding below o...
On the page http://www.foodepedia.co.uk/features/articles/2008/november/20081101alexjames.htm in IE6 the brown bar at the bottom takes up half the screen making it unreadable, I wondred if ...
I want to use a non-standard font for my navigation. I'm almost there, I think, using an image-replacement technique. The "only" problem is that my navigation items are no longer clickable. ...
Hi, Okay this stopped making sense for the last couple of hours, so this is my last resort. IE, no matter what, won't center the div tag using css, and i'm not reinventing someting new, jus...
http://feedingthespiders.com/testing/menu_test/ This menu looks perfect in Firefox but is way off in IE. I don't understand why. I have tried changing my padding to margins and several othe...
Hello, I'm struggling with a text-align issue on this page: http://www.bodyartforms.com/privacypolicy2.asp The "back to top" links make my background area larger rather than aligning to t...
I'm starting from scratch re-designing our entire site from the ground up with CSS. I'm pretty well along but I've noticed that on the content section of the page below, ONLY in IE, depending ...
I found this in a style sheet. What is it?
I found some coding online to allow for horizontal drop down menus.  Ever since I added that I can't seem to get my navigation bar to be fully colored in with gold #fc3.   The drop down menu i...
I currently have a background image on my website with a no-repeat.  If you have to scroll down to read content on the site, the content navigation scrolls too.  Therefore, when you are at the...
Hello, I'm print a page here: http://92.65.62.41:9021/proddemo/mobile.asp However the CSS background-color attribute doesn't seem to be formating.  Any thoughts how to fix? Thanks
Wondering what's the proper format for changing link colors/attributes for use inside a div.  The below code is not working (links are blue, hover is not working)
Hey Experts!! I have a template I made where the divs are supposed to be centered.  But on some pages where I have recordsets and other asp functions, the divs go off to the left.  I'm tryi...
Hi, I have this html <p class="qdet"><span>test</span> <div id="newtot">1000.00</div> </p> here are my css definitions p.qdet{      background:#eaf2f2;      color: #2B82AC;      font-weight: ...
Hi: Can any one please tell me how to i decrease the centre div as it too wide and is forcing the right div down to the bottom? is there any way i can change these left right and center width ...
I need some sort of quick hack that will allow me to do the following without me redesigning the whole template. I have a website which has it width set to body { margin: 0 auto; width: 80...
In the main menu of my joomla template, I can see what the css is for each link - but I can't seem to style it for the link that is active. (think I've been sitting here looking at this for ...
Hi Guys, I've been pulling my hair out on this one for a while. This is my layout: Everything sits in main container, header is width 100% and height 80px, footer is always at the botto...
I need this searI have to use these search parameters and make is display like the attached file. <form id="searchForm" method="get" action="/Search"> <input type="text" name="query" clas...
I'm working with the css in a zen cart template and I have one piece that isn't working right just yet. if you visit http://64.131.69.136/~nehemiah   you can see on the left "categories" an...
