The table height will always change and I want to make sure that the button is always directly under it.
I have a special page just for viewing on an iphone or other cell phone. I have made a small table, that if you zoom in, would fit an iphone quite nicely and be readable. Is there a way to t...
Hey everyone,
I am working on building a site and have run into a small problem that I cant seem to figure out. The site in question is:
http://74.220.215.52/~centrise/managed_it.php
I cannot get my page to display properly in Firefox. It looks okay in IE, but in FF the footer goes to the middle of the page and the background on the text div doesn't repeat. The footer div ...
On the homepage of this site ( http://pistachioconsulting.com/ ), there is a content box headed with the words, "About Pistachio". In most standards-compliant browsers, the text in this box fa...
So, someone has asked me to add RSS feeds to their site. Using
http://itde.vccs.edu/rss2js/build.php
Once I have the feed generated (code below) I need to stylize to make it look like t...
I am having issues with IE6 not taking the background image specified in the css style.
CSS style and code below. Works fine in all browser except IE6. Please assist.
--STYLE--
.hea...
I have created a css driven dropdown menuwhich works perfectly in FF. But in IE (of course) the positioning isn't right. If i remove position:absolute it works but the content of the page (the...
Just a qucik question...when I place my menu div before my logo div the menu aligns roughly where I want it ( like so http://www.mytesting.co.uk/stuff/template.html) . When I place ...
Hi
I have ASP.net page. The background is set in CSS as e.g.
background-image: url('../thegraphic.jpg');
I notice when printing that the background image is not printed...which is pro...
I have a website where certain words can become links to their definition. The words can be in apart of various blocks of text, all with varying font color/sizes. I want the hyperlinks to va...
Hello
Final tweaking on a website. The navigation links in the nav bar are working fine in IE 7 and firefox. But not working in IE 6. Actually ONE link is working and that is whatever l...
my client is seeing certain pages on this site shift to the left in firefox on mac. i can't see it because i don't have access to a mac.
http://mlaclaims.com/index.php
page jumps:
http:...
I've created a drop down menu using css. The menu is functional in all browsers except IE 5-6. In early IE browsers each button will stretch out and take up a whole row of space, forcing all t...
Hey Experts,
Please visit my website, www.dannyesquivel.com
You will see a section that says "Enlaces Importantes" which stands for important links. As you can see there is a bullet next...
I'm learning about CSS Style sheets and trying to frame a master page in ASP.NET using DIV tags and content place holders. The problem I am having is that that the text in the content area en...
Hello
I have a page with lots of text, some with different classes. I want to add left padding to the entire group of classes. What's the best way to do it.
Look for the URL in my next...
Hi I am having a little trouble with my css- should be an easy fix for anyone who knows css (I am new to it). I am editing the css in Dreamweaver cs3. I am editing a template also- didnt des...
Within following site;
http://www.theceocircle.com/how_works.php?view=sphere_of_influence
there is an intermittent problem with the body text. Sometimes it displays the text alot...
Can you please explain me with simple examples what are : Universal Style Class & Element Specific Style Class in - CSS / DHTML. BTW: What are the differences between these two.
On this page:
http://www.glowfishtw.com/flagfootball/picstrip.htm
there is a 20px border around the flash object. It's applied using css class="PicStrip". It's displayed properly in Chro...
I am using CSS to layout a webpage. The webpage is populated dynamically. I need the height of my content to be at least 600px. But, if the dynamic content's height is greater than 600px, I...
I've been looking at this problem for a day or two now and I really can't get to the bottom of the issue!
Go To:
http://www.hotelresevationsystem.com/index.php?option=com_reserva...
I'm going from using tables to CSS layouts, and I've run into a snag.
Can't get the text to default to the TOP along with the IMAGE -- in other words, they need to be aligned with one anoth...
Hi Experts,
I'm fairly proficient with CSS, but I don't work with percentage based layouts that often. I'm trying to create a fixed width layout that is always centered, but the footer belo...
