Hello please look at this page: http://positivedailynews.com/ (work in progress)
Please look at it in both Firefox and IE. In FIrefox version 2 the page is "perfecdt". Specificalliy you ...
I have a rollover image that will pop up a div that will show links.
The div will auto to the right side of the image using the css code for the div left:auto.
My problem is that the ima...
I have started builiding my first website and i am having problems with the positioning of my horziontal navigation menu. i can not get it to align under the header of my page and in diff...
I want to center an image vertically and I can't seem to figure out what I need to change in my code to do this. Any help would greatly be appreciated!
Hi everyone, thank you in advance to anyone who gives this post a look over.
I am trying to use PNG's in a website design (works perfect in IE7/MOZ) and trying to allow the design to be ren...
Go to:
wolfcast dot com/contact.php
The padding of the "Contact form" fieldset is not correctly set. It should have 0.5em for top, right, bottom, left... But currently it's not working (at...
I have this and what I am trying to do is keep the box with this div
<div style="width:60%; border:solid 1px; float:right;">
Box containing upward box on right
on right hand upper corner ...
i get this error message from w3 css validator.
do you know how to fix this?
http://www.filemakersupport.net/kad/design02/
I am having trouble with my positioning again!!!
I cannot seem to get my content dvi to position immediately to the right of my leftmenu div... I seems to drop down as if I have plac...
Is it possible to have a table that expands to whatever height your brower window is at becuase setting it to 100% height dosn't seem to work
It's the usual issue..
A page that looks fine in Firefox, but is a little off in IE 6 and 7
I will post the URL in my next comment.
Rowby
I want to superimpose two images in css.
That two images stay in <divs> diferent, and are position 'absolute'.
What kind of images I have to do to be transparency in the overlap.
jpg? png? ...
I am trying to set the layout on a menu, and I can't quite get it to work. I am trying to get the spacing between each menu item the same distance, with an roughly equal gap on the left of th...
Hey,
I have been curious for a long time now. What is the best way to work with CSS and opacity on an element, I have seen:
filter:alpha(opacity=85);
-moz-opacity:0.85;
-kh...
Hello people
I'm having a problem with a layout.
I've got it working here
http://krayonrecordings.kaen.org/fivestoreyprojects/layout.html
but once I try to use the php inlucde funct...
Hello all
I created a graphic bullet list and adding some padding o the css. The text moved over but the bullets are still flush right.
In my next comment I will give the URL.
Thank...
Here: http://www.cantinho.org/test5.html
I have a "underline" on over, defined like this:
.linksprincipais#navigation ul li a:hover{
border-bottom: 10px solid black;
What I'd like ...
I have a Div as follows:
<div id="Div1" class="right" style="position: relative; background-color:Black; color: rgb(255, 255, 255); width:100%">
Why can't I see "Div1" in code? ...
I would like my site to be centered when requested. So, regardless of the user's monitor size, the site is always in the center.
I tried using the HTML element <center>; it does work; but ...
What is the code to acheive this, my css is very limited, but this is needed for the design of my site.
<div id="foo">
..... more markup .....
</div>
Assume all CSS rules for the content inside have an id selector of "foo" as the prefix
Examples:
#foo p{...}
#foo #myspan{....}
Is ...
Are both of these valid?
.abc {text-decoration: underline; color: red; !important}
.xyz {text-decoration: underline; color: red !important}
I have multiple areas of our site that i want to appear innactive until the user clicks on it, then it appears active.
To pull this off, i need a code that will make a table or a cell or a...
Hi, Do someone know why this css class does not dim the background? if you have an alternative one please provide it.
Hi
In my follow up comment I will include the url. I have a large header image that is a background image. I need to create a link (to go to the home page).
What's the best way to do t...
