Top CSS Solutions: 651 - 675 of 731
Hi, Could you please provide me a sample style sheet so I can use in my pages. I just need a sample which has styles for several controls like textbox, label, page background etc. Thank you...
hello, i have created a banner with <div> tags and z-index with overlying text layer.  it shows up correct in firefox but in ie the text breaks lines after each word. does anyone see an issue...
Hi everyone, I'm don't think I understand style sheets like I thought I did...  Here is some sample HTML, why isn't my table being drawn in blue? <HTML> <HEAD> <STYLE> TABLE.bluebkgd ...
i need that the firs line will be in white background...the first line is the line wich will be sticking to the top of the page and its width will be 100%- means full width size of the page......
Hi I am revising a web page from a template, (html page that includes css, modified in dreamweaver). I am having a link problem- I know its probably something simple but I cant figure it o...
As usual, IE isn't rendering valid CSS properly...! I'm currently developing a website for my church. The development area is http://www.dox4.co.uk/romfordsa. The problem is the menu. I...
I am desperate.  If I could offer chocolate of money instead of points, I'd consider it.  I have been struggling with positioning the elements on our home page for three days now.  They're wor...
Hello, I know how to work with basic CSS, but I created a layout that is much more complex then anything I have done before.  I would like to try to make it intelligently in CSS, but I don'...
i'm working on this website; http://www.filemakersupport.net/kad/design02/ i have no problem with firefox and safari but Internet Explorer. do you know what's wrong with it?
I want the below list to display flush up against the left margin of the table which holds it. However, there is about 80 -90 pixels between the left and the bullet. How can I have it sit flus...
I have this website www.electclay.org and I am having the following issues: I have thickbox js and css on my photogallery pages and right now, my menu has a list-style that the bullets are ac...
Hi- This is my first purely CSS site, and I'm fairly happy with is so far (only home page done). See it at http://diabeticmealprograms.com/newsite/. In IE, the home nav button is over to th...
i need to make this website design with css; http://www.filemakersupport.net/kad/design01/ right now i don't know how to figure out how to set background color. http://www.filemakersupport....
Please see the code below. It looks fine in IE 7 but sees to be not aligning correctly in fire fox. Please see the code below and the pictures attached. Thanks
my nav menu uses css to display a drop down list and works fine in FF etc however not in IE6/7 despite using the csshover2.htc behavior to fix IE's lack of li:hover support. It appears to be s...
ok im messing around with the css of some text within php... Code: "<p style=\"background: #e4ebeb; border: 1px solid #555555; padding: 6px;\"><span style=\"font: bold 10px Courier New;\...
how do implement "tahoma condensed" font into my web page?  i can use tahoma but not condensed.  what is the css for it?
I am using a simple CSS to pop up an info box. The popup shows up, looks good in FF, but looks terrible in IE6. Here is the CSS I'm using: a.info {   position:relative; /* this is the key ...
Trying desperately to move away from tables. Thought life was grand until I noticed when the content for my body div grows past a certain length, the text overflows past the footer.  If i set ...
I am using this css class in my div tag.  I need a div tag that will autogrow depending of how big data  is instead of fixed size.   is this possible?  some of my data is being cut off due to...
Is there any way of adding padding around a table and with the table inside a box (with a border) using CSS. I have tried lots of diferent ways and I'm stuck. I'm trying to create the look of ...
I have the following class: .myClass{ width:100% } And used here <table class="myClass"> How do I select all <tr> and <td> tag within this table to have a certain, say, padding p...
Is this right? <%@ Page Language="C#" AutoEventWireup="true" CodeFile="Page_EnterRecordLocator.aspx.cs" Inherits="Page_EnterRecordLocator" %> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0...
Trying to move away from tables to divs for layout and was wondering how important are the z-values.  For example, if the divs do not overlap, does it matter what their z-value is in the even ...
The code below is a little lengthy but it will show you what I have working and is editable.  There is a horizontal menu. When the top menu items moused over the sub menu items for that item a...
